Ir para o conteúdo principal
Samsung Galaxy Note Headphone Jack and Earpiece Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Samsung Galaxy Note Headphone Jack and Earpiece Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy Note Headphone Jack and Earpiece Replacement, Battery: passo 1, imagem 2 %32 Samsung Galaxy Note Headphone Jack and Earpiece Replacement, Battery: passo 1, imagem 3 %32
    • Make sure the screen is face-down and the camera is opposite you.
    • Insert the flat end of a spudger into the phone's top right rectangular slot.
    • Use the spudger as a lever to pry open the back of the phone.
  2. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: passo 2, imagem 1 %32
    • With the spudger still inserted, carefully slide the spudger down the side of the phone.
    • Gently peel off the back cover with your hand.
  3. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: passo 3, imagem 1 %32
    • Place the spudger in the battery's bottom right slot.
    • Gently pry to remove the battery.
  4. Samsung Galaxy Note Headphone Jack and Earpiece Replacement, Midframe: passo 4, imagem 1 %32
    • Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
  5. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: passo 5, imagem 1 %32
    • Remove the stylus from the bottom of the phone.
  6. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: passo 6, imagem 1 %32 Samsung Galaxy Note Headphone Jack and Earpiece Replacement: passo 6, imagem 2 %32 Samsung Galaxy Note Headphone Jack and Earpiece Replacement: passo 6, imagem 3 %32
    • Pry all the way around the sides with a plastic pry tool and gently pop off the midframe.
    • If the cover does not come off easily, continue to pry along the phone's perimeter.
    • This step can take some patience. Prying too hard or forcing the screen off can crack or scratch the screen and break the thin plastic around the stylus case.
    • Separate the midframe from the phone. The midframe should now pull off easily.
  7. Samsung Galaxy Note Headphone Jack and Earpiece Replacement, Headphone Jack and Earpiece: passo 7, imagem 1 %32
    • Use the spudger to pry up the yellow ribbon cable.
  8. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: passo 8, imagem 1 %32
    • Use the spudger to pry up the long, green ribbon next to the yellow one you just pried up.
    • Push the green ribbon back to access the black bracket underneath it.
  9. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: passo 9, imagem 1 %32
    • Use your fingers to gently lift up the black bracket and set it aside.
  10. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: passo 10, imagem 1 %32 Samsung Galaxy Note Headphone Jack and Earpiece Replacement: passo 10, imagem 2 %32
    • Flip the spudger around and insert the pointy end into the headphone jack.
    • Lift the headphone jack directly upwards using the spudger as a lever. This will also remove the connected speaker.
    • The headphone jack and earpiece are held down with an adhesive, so removing them might take some force.
Conclusão
David Ritter
Membro desde: 04/14/13
758 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 3-45, Amido Spring 2013 Membro de Cal Poly, Team 3-45, Amido Spring 2013
CPSU-AMIDO-S13S3G45
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 11
Duração total: 1,079
