Ir para o conteúdo principal
Samsung Galaxy Note 4 Motherboard Replacement
O que você precisa
  1. Samsung Galaxy Note 4 Motherboard Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy Note 4 Motherboard Replacement, Rear Case: passo 1, imagem 2 %32
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
    Pergunte ao FixBot
    Comentar
  2. Samsung Galaxy Note 4 Motherboard Replacement, Battery: passo 2, imagem 1 %32
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  3. Samsung Galaxy Note 4 Motherboard Replacement, SIM Card: passo 3, imagem 1 %32 Samsung Galaxy Note 4 Motherboard Replacement, SIM Card: passo 3, imagem 2 %32
    • Remove the SIM card by first pushing the card slightly out of its housing, then pulling it the rest of the way.
    Pergunte ao FixBot
    Comentar
  4. Samsung Galaxy Note 4 Motherboard Replacement, Midframe: passo 4, imagem 1 %32
    • Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Grasp the cap of the S Pen and remove it from its slot in the midframe.
    Pergunte ao FixBot
    Comentar
  5. Samsung Galaxy Note 4 Motherboard Replacement: passo 5, imagem 1 %32 Samsung Galaxy Note 4 Motherboard Replacement: passo 5, imagem 2 %32 Samsung Galaxy Note 4 Motherboard Replacement: passo 5, imagem 3 %32
    • Insert a plastic opening tool between the midframe and the display assembly.
    • Work the plastic opening tool around the perimeter of the phone to break the adhesive.
    • This adhesive is relatively weak, so no heat gun should be necessary.
    • Be careful to not separate the front glass panel from the rest of the display assembly, as it is still held together with adhesive.
    Pergunte ao FixBot
    Comentar
  6. Samsung Galaxy Note 4 Motherboard Replacement: passo 6, imagem 1 %32
    • Use a plastic opening tool to loosen the clasps around the battery housing.
    Pergunte ao FixBot
    Comentar
  7. Samsung Galaxy Note 4 Motherboard Replacement: passo 7, imagem 1 %32 Samsung Galaxy Note 4 Motherboard Replacement: passo 7, imagem 2 %32 Samsung Galaxy Note 4 Motherboard Replacement: passo 7, imagem 3 %32
    • Push on the battery housing to separate the midframe from the display assembly.
    • You will have to apply a reasonable amount of pressure to separate the two parts.
    • If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
    Pergunte ao FixBot
    Comentar
  8. Samsung Galaxy Note 4 Motherboard Replacement, Motherboard: passo 8, imagem 1 %32
    • Remove the two 2.9 mm Phillips #00 screws.
    Pergunte ao FixBot
    Comentar
  9. Samsung Galaxy Note 4 Motherboard Replacement: passo 9, imagem 1 %32 Samsung Galaxy Note 4 Motherboard Replacement: passo 9, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a set of tweezers to remove the two antenna cables.
    Pergunte ao FixBot
    Comentar
  10. Samsung Galaxy Note 4 Motherboard Replacement: passo 10, imagem 1 %32 Samsung Galaxy Note 4 Motherboard Replacement: passo 10, imagem 2 %32 Samsung Galaxy Note 4 Motherboard Replacement: passo 10, imagem 3 %32
    • Use a set of tweezers or the flat end of a spudger to disconnect the two ribbon cable connectors.
    Pergunte ao FixBot
    Comentar
  11. Samsung Galaxy Note 4 Motherboard Replacement: passo 11, imagem 1 %32
    • Gently lift the motherboard out of the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
113 outras pessoas executaram este guia.
Geoff Wacker
Membro desde: 09/30/13
92.869 Reputação
Autoria de 89 guias
67Comentários do guia
Are all variants of the note 4 the same? An att mobo could go into a vzw/sprint body or vice versa?
Jeb - Responder Compartilhar
I would also really like an answer to this question
pcwireless - Responder Compartilhar
No. Even Samsung wouldn't accept even a paid repair because parts between models are incompatible.
I've tried to have an SM-910G here and if you are to replace it with an SM-910C, you'll also need to replace the front and back cameras.
Ian Troy Alvaran - Responder Compartilhar
I have done a few Note 4 motherboard replacements...about 10 or so. I have not been able to simply "To reassemble your device, follow these instructions in reverse order." I always have to separate the screen from the mid frame in order to plug the 2 top ribbon cables back to the motherboard. I can't figure out a way to get the ribbon cables plugged back in without doing so. This screen separation process is very tedious, long, and stressful as it could crack the AMOLED screen if you're not careful. If someone can show me exactly how to simply, "To reassemble your device, follow these instructions in reverse order" it'll make it a lot easier for me. Thanks.
KengkoyFlip - Responder Compartilhar
Agreed. That screen was by far the most difficult screen ive ever removed from a phone. It would be SOOO much easier if it were broken and you didn't care.
trentmrobertson - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 99
Ao todo: 150,787
