Ir para o conteúdo principal
Samsung Galaxy Note 3 Rear Facing Camera Replacement
O que você precisa
  1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove the rear case: passo 1, imagem 1 %32
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
    Pergunte ao FixBot
    Comentar
  2. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: passo 2, imagem 1 %32 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: passo 2, imagem 2 %32
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
    Pergunte ao FixBot
    Comentar
  3. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: passo 3, imagem 1 %32 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: passo 3, imagem 2 %32
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
    Pergunte ao FixBot
    Comentar
  4. Samsung Galaxy Note 3 Rear Facing Camera Replacement, S Pen: passo 4, imagem 1 %32
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
    Pergunte ao FixBot
    Comentar
  5. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unscrew Back Chassis: passo 5, imagem 1 %32
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
    Pergunte ao FixBot
    Comentar
  6. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Back Chassis: passo 6, imagem 1 %32
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
    Pergunte ao FixBot
    Comentar
  7. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: passo 7, imagem 1 %32 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: passo 7, imagem 2 %32
    • Remove the single screw beside headphone jack.
    Pergunte ao FixBot
    Comentar
  8. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: passo 8, imagem 1 %32 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
    Pergunte ao FixBot
    Comentar
  9. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Motherboard Removal: passo 9, imagem 1 %32
    • Pull up on the motherboard with tweezers.
    Pergunte ao FixBot
    Comentar
  10. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unclipping the Camera: passo 10, imagem 1 %32
    • Unclip the camera connecting cable using the plastic opening tool from the motherboard
    • Remove loose camera from base
    Pergunte ao FixBot
    Comentar
Conclusão
37 outras pessoas executaram este guia.
Brittany Gail
Membro desde: 09/23/14
8.581 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team 2-2, Blackwell Fall 2014 Membro de USF Tampa, Team 2-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G2
4 Membros
Autoria de 25 guias
3Comentários do guia
Awesome, phone disassembly and fingernail painting at same time :) Thanks for your time to post this!
Chris G - Responder Compartilhar
Hi
Thanks for the nice instructions
Do you know if I can use a Note 4 camera (or any better!) for my Note 3?
Are they different in connections?
Thanks
hameidfehri - Responder Compartilhar
I shall be very thankfull for this act of kindness
Malik wajdan ali - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 70
Ao todo: 14,220
