Ir para o conteúdo principal
Samsung Galaxy Note 3 Midframe Replacement
O que você precisa
  1. Samsung Galaxy Note 3 Midframe Replacement, Remove the rear case: passo 1, imagem 1 %32
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
    Pergunte ao FixBot
    Comentar
  2. Samsung Galaxy Note 3 Midframe Replacement, Remove Case from the Base: passo 2, imagem 1 %32 Samsung Galaxy Note 3 Midframe Replacement, Remove Case from the Base: passo 2, imagem 2 %32
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
    Pergunte ao FixBot
    Comentar
  3. Samsung Galaxy Note 3 Midframe Replacement, Battery: passo 3, imagem 1 %32 Samsung Galaxy Note 3 Midframe Replacement, Battery: passo 3, imagem 2 %32
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
    Pergunte ao FixBot
    Comentar
  4. Samsung Galaxy Note 3 Midframe Replacement, S Pen: passo 4, imagem 1 %32
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
    Pergunte ao FixBot
    Comentar
  5. Samsung Galaxy Note 3 Midframe Replacement, Unscrew Back Chassis: passo 5, imagem 1 %32
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
    Pergunte ao FixBot
    Comentar
  6. Samsung Galaxy Note 3 Midframe Replacement, Remove Back Chassis: passo 6, imagem 1 %32
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
    Pergunte ao FixBot
    Comentar
Conclusão
48 outras pessoas executaram este guia.
Brittany Gail
Membro desde: 09/23/14
8.581 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team 2-2, Blackwell Fall 2014 Membro de USF Tampa, Team 2-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G2
4 Membros
Autoria de 25 guias
2Comentários do guia
the info provided is perfectly narrated and illustrated, however this guide is incomplete and potentially misleading. unintentionally im sure..
the guide is titled "Mid Frame Replacement" and all this guide tells you is how to remove the rear frame (still 2 separate components) it has made no mention of the fact the mid-frame is fused to the screen assembly nor any of the ribbon/cables thats quite possibly may affect the reader, and im afraid some may order a mid frame thinking they can handle this, only to be puzzled when the back comes off and they are left pondering what next.. im not trying to be spiteful, you guys are amazing and i always check your guides before a repair/swap ect that ive not done before to make sure i dont miss a hidden ribbon cable or device specific shortcut, im simply trying to look for the beginners that are aspiring to become one of ..
That being said love the site guys!! keep up teh good work, i use you at least a half dozen times a week :)
regards,
vick0den
shane walker - Responder Compartilhar
i know i need to know how to remove the mid frame from the lcd as i need to replace mine its cracked on the outside and i dont want to break my lcd as i need it still , this guide sucks.
Kenneth A - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 49
Ao todo: 20,231
