Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide instructs on how to replace the rear facing camera.
O que você precisa
Before starting, ensure device is completely turned off.
On the back of phone, locate the slot on the top left corner.
Insert plastic opening tool or fingernail and pull up on the back plate.
With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
Remove the 14 3.45 mm Phillips #000 screws from the assembly.
Gently, insert plastic opening tool into seam above the volume buttons of your phone.
On the back of the motherboard, remove the connector of the rear facing camera from the motherboard.
Camera is now detached from device.
Uma outra pessoa concluiu este guia.
