Ir para o conteúdo principal
Samsung Galaxy M51 Screen Replacement
O que você precisa
  1. Samsung Galaxy M51 Screen Replacement, How to remove the SIM Tray: passo 1, imagem 1 %32 Samsung Galaxy M51 Screen Replacement, How to remove the SIM Tray: passo 1, imagem 2 %32 Samsung Galaxy M51 Screen Replacement, How to remove the SIM Tray: passo 1, imagem 3 %32
    • Insert a SIM eject tool into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    • When reinserting the cards, make sure to properly orient them in the tray.
    Pergunte ao FixBot
  2. Samsung Galaxy M51 Screen Replacement, Heat an iOpener: passo 2, imagem 1 %32
    • Before beginning this procedure, completely power off your phone.
    • Prepare an iOpener and apply it to the back cover for at least two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Pergunte ao FixBot
  3. Samsung Galaxy M51 Screen Replacement, Create an opening gap: passo 3, imagem 1 %32 Samsung Galaxy M51 Screen Replacement, Create an opening gap: passo 3, imagem 2 %32 Samsung Galaxy M51 Screen Replacement, Create an opening gap: passo 3, imagem 3 %32
    • Apply a suction handle to the back cover, as close to the USB-C port as possible.
    • Lift the back cover's bottom edge with your suction handle, opening a slight gap between the back cover and the frame.
    • Insert the tip of an opening pick in the gap you created.
    • Slide the opening pick to the bottom left corner and leave it there.
    Pergunte ao FixBot
  4. Samsung Galaxy M51 Screen Replacement, Slice through the adhesive: passo 4, imagem 1 %32 Samsung Galaxy M51 Screen Replacement, Slice through the adhesive: passo 4, imagem 2 %32
    • Insert a second opening pick and slide it from the bottom left corner to the bottom right corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    Pergunte ao FixBot
  5. Samsung Galaxy M51 Screen Replacement: passo 5, imagem 1 %32 Samsung Galaxy M51 Screen Replacement: passo 5, imagem 2 %32
    • Insert a third opening pick under the bottom right corner of the back cover.
    • If you have any trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide it along the right edge of the phone to the top right corner to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Pergunte ao FixBot
  6. Samsung Galaxy M51 Screen Replacement: passo 6, imagem 1 %32 Samsung Galaxy M51 Screen Replacement: passo 6, imagem 2 %32
    • Insert a fourth opening pick under the top right corner.
    • Slide it along the top edge to the left corner to cut the adhesive.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
    Pergunte ao FixBot
  7. Samsung Galaxy M51 Screen Replacement: passo 7, imagem 1 %32 Samsung Galaxy M51 Screen Replacement: passo 7, imagem 2 %32
    • Insert a fifth opening pick on the top left corner and slide it along the edge to cut the remaining adhesive.
    Pergunte ao FixBot
  8. Samsung Galaxy M51 Screen Replacement, Remove the back cover: passo 8, imagem 1 %32
    • Remove the back cover.
    Pergunte ao FixBot
  9. Samsung Galaxy M51 Screen Replacement, Disconnect the fingerprint sensor: passo 9, imagem 1 %32 Samsung Galaxy M51 Screen Replacement, Disconnect the fingerprint sensor: passo 9, imagem 2 %32
    • Use the pointy end of a spudger to disconnect the fingerprint sensor from the motherboard.
    Pergunte ao FixBot
  10. Samsung Galaxy M51 Screen Replacement, Remove the screws: passo 10, imagem 1 %32
    • Remove the 15 4.0 mm-long Phillips #00 screws securing the midframe.
    Pergunte ao FixBot
  11. Samsung Galaxy M51 Screen Replacement, Release the plastic clips: passo 11, imagem 1 %32 Samsung Galaxy M51 Screen Replacement, Release the plastic clips: passo 11, imagem 2 %32 Samsung Galaxy M51 Screen Replacement, Release the plastic clips: passo 11, imagem 3 %32
    • The midframe is held by plastic clips.
    • Insert an opening pick between midframe and display near the usb-c port.
    • Slide the opening pick to bottom right corner to release the plastic clips.
    Pergunte ao FixBot
  12. Samsung Galaxy M51 Screen Replacement: passo 12, imagem 1 %32 Samsung Galaxy M51 Screen Replacement: passo 12, imagem 2 %32 Samsung Galaxy M51 Screen Replacement: passo 12, imagem 3 %32
    • Slide the opening pick along the right edge to release the plastic clips.
    Pergunte ao FixBot
  13. Samsung Galaxy M51 Screen Replacement: passo 13, imagem 1 %32 Samsung Galaxy M51 Screen Replacement: passo 13, imagem 2 %32 Samsung Galaxy M51 Screen Replacement: passo 13, imagem 3 %32
    • Slide the opening pick along the top edge to release the midframe from the plastic clips.
    Pergunte ao FixBot
  14. Samsung Galaxy M51 Screen Replacement: passo 14, imagem 1 %32 Samsung Galaxy M51 Screen Replacement: passo 14, imagem 2 %32 Samsung Galaxy M51 Screen Replacement: passo 14, imagem 3 %32
    • Slide the opening pick along the left edge to release the plastic clips.
    Pergunte ao FixBot
  15. Samsung Galaxy M51 Screen Replacement, Remove the midframe: passo 15, imagem 1 %32
    • Remove the midframe.
    Pergunte ao FixBot
  16. Samsung Galaxy M51 Screen Replacement, Battery Disconnect: passo 16, imagem 1 %32 Samsung Galaxy M51 Screen Replacement, Battery Disconnect: passo 16, imagem 2 %32
    • Use the flat end of a spudger to disconnect the battery.
    Pergunte ao FixBot
  17. Samsung Galaxy M51 Screen Replacement, Disconnect the screen: passo 17, imagem 1 %32 Samsung Galaxy M51 Screen Replacement, Disconnect the screen: passo 17, imagem 2 %32
    • Use the flat end of a spudger to disconnect the display cable from the daughterboard.
    Pergunte ao FixBot
  18. Samsung Galaxy M51 Screen Replacement, Heat an iOpener: passo 18, imagem 1 %32
    • Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath.
    • The adhesive is placed on the edges of the display. Make sure that the iOpener covers all edges and repeat the heating process if necessary.
    Pergunte ao FixBot
  19. Samsung Galaxy M51 Screen Replacement, Create an opening gap: passo 19, imagem 1 %32 Samsung Galaxy M51 Screen Replacement, Create an opening gap: passo 19, imagem 2 %32 Samsung Galaxy M51 Screen Replacement, Create an opening gap: passo 19, imagem 3 %32
    • Apply a suction handle near the bottom edge.
    • If the screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Pull up on the suction up with strong, steady force to create a gap.
    • Insert an opening pick into the gap between display and the frame.
    Pergunte ao FixBot
  20. Samsung Galaxy M51 Screen Replacement, Slice through the adhesive: passo 20, imagem 1 %32 Samsung Galaxy M51 Screen Replacement, Slice through the adhesive: passo 20, imagem 2 %32
    • Insert a second opening pick and slide it to the bottom right corner to cut the adhesive.
    Pergunte ao FixBot
  21. Samsung Galaxy M51 Screen Replacement: passo 21, imagem 1 %32 Samsung Galaxy M51 Screen Replacement: passo 21, imagem 2 %32 Samsung Galaxy M51 Screen Replacement: passo 21, imagem 3 %32
    • Insert a third opening pick and slide it along the left edge to cut the adhesive.
    • Leave the opening pick on the top right corner.
    Pergunte ao FixBot
  22. Samsung Galaxy M51 Screen Replacement: passo 22, imagem 1 %32 Samsung Galaxy M51 Screen Replacement: passo 22, imagem 2 %32 Samsung Galaxy M51 Screen Replacement: passo 22, imagem 3 %32
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough to cut the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert a fourth opening pick and slide it to the top left corner to cut the adhesive.
    Pergunte ao FixBot
  23. Samsung Galaxy M51 Screen Replacement: passo 23, imagem 1 %32 Samsung Galaxy M51 Screen Replacement: passo 23, imagem 2 %32 Samsung Galaxy M51 Screen Replacement: passo 23, imagem 3 %32
    • Insert a fifth opening pick and slide it along the left edge to cut the remaining adhesive.
    Pergunte ao FixBot
  24. Samsung Galaxy M51 Screen Replacement: passo 24, imagem 1 %32 Samsung Galaxy M51 Screen Replacement: passo 24, imagem 2 %32 Samsung Galaxy M51 Screen Replacement: passo 24, imagem 3 %32
    • Thread the display cable through the frame.
    Pergunte ao FixBot
  25. Samsung Galaxy M51 Screen Replacement: passo 25, imagem 1 %32
    • Remove the display.
    Pergunte ao FixBot
Conclusão
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
13 outras pessoas executaram este guia.
Adriana Zwink
Membro desde: 12/18/19
66.875 Reputação
Autoria de 167 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 25.804 guias
11Comentários do guia
Vielen Dank, für diese Anleitung! Ich würde auch gerne diese Anleitung nutzen, um mein kaputtes Display selbst zu tauschen, jedoch finde ich in den Weiten des Internets kein Ersatzglas für das M51. Kann mir jemand einen passenden link nennen? Da ich nichts passendes gefunden habe, wäre meine nächste Frage, ob das Display vom S20 Plus kompatibel wäre, da es die gleichen Maße misst..?Vielen Dank im voraus!
Vg
Marv
Marv Zockt - Responder Compartilhar
Hi,
such mal nach einem M515 Display-Glas. Das ist kompatibel.
Mfg
Mr. Jingels - Responder Compartilhar
Merci beaucoup !
Grâce à vous j’ai pu changer moi même l’écran de la collègue amie de ma mère et elle va être très heureuse !
Vous apportez de la joie, et vos tutos sont vraiment de qualité bravo !
Antoine
Antoine HIEZELY - Responder Compartilhar
Is a71 screen compatible with m51?
abodeabodeabode60 - Responder Compartilhar
Humko abhi sikna hai
shanihasnain912 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 27
Últimos 30 dias: 153
Ao todo: 15,103
