Ir para o conteúdo principal
Samsung Galaxy J3V Front Camera Replacement
O que você precisa
  1. Samsung Galaxy J3V Front Camera Replacement, Front Camera: passo 1, imagem 1 %32 Samsung Galaxy J3V Front Camera Replacement, Front Camera: passo 1, imagem 2 %32 Samsung Galaxy J3V Front Camera Replacement, Front Camera: passo 1, imagem 3 %32
    • Place your thumb on the top left corner and pry the tab open and lift off the back cover.
    Pergunte ao FixBot
    Comentar
  2. Samsung Galaxy J3V Front Camera Replacement: passo 2, imagem 1 %32 Samsung Galaxy J3V Front Camera Replacement: passo 2, imagem 2 %32 Samsung Galaxy J3V Front Camera Replacement: passo 2, imagem 3 %32
    • Remove the ten 2.0 mm screws with the Phillips #J000 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Samsung Galaxy J3V Front Camera Replacement: passo 3, imagem 1 %32 Samsung Galaxy J3V Front Camera Replacement: passo 3, imagem 2 %32 Samsung Galaxy J3V Front Camera Replacement: passo 3, imagem 3 %32
    • Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards.
    • If this is the first time the screen is being removed then there will be adhesive around the edges of the screen. It may be difficult to remove the screen because of this adhesive seal and it is going to take a few tries and some force to pry the entire screen off.
    Pergunte ao FixBot
    Comentar
  4. Samsung Galaxy J3V Front Camera Replacement: passo 4, imagem 1 %32 Samsung Galaxy J3V Front Camera Replacement: passo 4, imagem 2 %32 Samsung Galaxy J3V Front Camera Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to flip tab of the front camera to remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
Carry Corrales
Membro desde: 09/28/17
792 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S3-G3, Nance Fall 2017 Membro de USF Tampa, Team S3-G3, Nance Fall 2017
USFT-NANCE-F17S3G3
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 22
Ao todo: 771
