Ir para o conteúdo principal
Samsung Galaxy J3 Home Key Replacement
O que você precisa
  1. Samsung Galaxy J3 Home Key Replacement, Home Key: passo 1, imagem 1 %32
    • Separate the back casing from the phone by carefully using your fingers to pry them apart.
  2. Samsung Galaxy J3 Home Key Replacement: passo 2, imagem 1 %32
    • Remove the battery.
  3. Samsung Galaxy J3 Home Key Replacement: passo 3, imagem 1 %32
    • Remove all ten screws by using a Phillips #000 screwdriver.
  4. Samsung Galaxy J3 Home Key Replacement: passo 4, imagem 1 %32
    • Use the flat side of a spudger to remove the middle frame bezel.
    • Do not twist or wrench the spudger during this step as it will cause the screen to crack.
  5. Samsung Galaxy J3 Home Key Replacement: passo 5, imagem 1 %32
    • Gently pull the glass up from the side of the phone and push the home button out.
    • When you pull the glass up, it will make a popping sound. This is normal.
  6. Samsung Galaxy J3 Home Key Replacement: passo 6, imagem 1 %32
    • Replace the home button and press the glass back in place.
Conclusão
3 outras pessoas executaram este guia.
2Comentários do guia
NEVER NEVER do this!!!! In the last picture I can see the LCD broken apart!!! You may never open an J3 like this, because the LCD screen will brake and this is what happen in the last 2 pictures, this man separated the screen in 2 parts and now the screen does not work. Check some videos in youtube and you will know what I am saying.
Leonardo Sierra - Responder Compartilhar
you see, you clearly know nothing about phones, because the last picture shows nothing resembling a broken lcd. however, there is a much simpler way of doing this and he did take an over-complicated approach. sidenote: if you use youtube for your information instead of guides by professionals, you have some issues.
Blins Cat - Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 54
Ao todo: 3,340
