Introdução
Follow this guide to remove the MicroSD memory and the SIM card for your Samsung Galaxy J3.
Be sure to power off your phone before following this guide.
O que você precisa
Insert a fingernail or the flat end of a spudger into the divot to the left of the rear-facing camera.
Gently pry the rear cover away from the phone until all the plastic clips holding the cover are released.
Insert a fingernail or the flat end of a spudger into the divot below the battery pack.
Pry the battery pack out of its recess.
Remove the battery pack.
Use a fingertip to slide the MicroSD card out of its slot.
Remove the MicroSD card from the phone.
Repeat the procedure to remove the SIM card from its slot.
Repair didn’t go as planned? Check out our Samsung Galaxy J3 (2016) Answers community for troubleshooting help.
4 outras pessoas executaram este guia.
