Ir para o conteúdo principal
Samsung Galaxy J3 (2016) Battery Replacement
O que você precisa
  1. Samsung Galaxy J3 (2016) Battery Replacement, Rear Cover: passo 1, imagem 1 %32 Samsung Galaxy J3 (2016) Battery Replacement, Rear Cover: passo 1, imagem 2 %32
    • Insert a fingernail or the flat end of a spudger into the divot to the left of the rear-facing camera.
    • Gently pry the rear cover away from the phone until all the plastic clips holding the cover are released.
  2. Samsung Galaxy J3 (2016) Battery Replacement: passo 2, imagem 1 %32
    • Remove the rear cover.
    • To reinstall the rear cover, align it to the back of the phone, and squeeze the perimeter of the phone to snap all the clips into place.
  3. Samsung Galaxy J3 (2016) Battery Replacement, Battery: passo 3, imagem 1 %32 Samsung Galaxy J3 (2016) Battery Replacement, Battery: passo 3, imagem 2 %32 Samsung Galaxy J3 (2016) Battery Replacement, Battery: passo 3, imagem 3 %32
    • Insert a fingernail or the flat end of a spudger into the divot below the battery pack.
    • Pry the battery pack out of its recess.
    • If you use the spudger, do not push too hard or you will puncture the battery pack.
    • Remove the battery pack.
Conclusão
Repair didn’t go as planned? Check out our Samsung Galaxy J3 (2016) Answers community for troubleshooting help.
7 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
257.468 Reputação
Autoria de 529 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 17.895 guias
Um comentário
Hmm I can't seem to get the back cover off my phone. This phone is a POS, always has been. It's slow, hard to use, and for almost 300.00 bucks it lasted about 2 years. What a racket these phone companies have going.
Mare Tomaski - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 19
Últimos 30 dias: 107
Duração total: 12,632
