Ir para o conteúdo principal
Samsung Galaxy J1 Volume Button Replacement
O que você precisa
  1. Samsung Galaxy J1 Volume Button Replacement, Midframe: passo 1, imagem 1 %32
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
    Pergunte ao FixBot
    Comentar
  2. Samsung Galaxy J1 Volume Button Replacement: passo 2, imagem 1 %32 Samsung Galaxy J1 Volume Button Replacement: passo 2, imagem 2 %32
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
    Pergunte ao FixBot
    Comentar
  3. Samsung Galaxy J1 Volume Button Replacement: passo 3, imagem 1 %32
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
    Pergunte ao FixBot
    Comentar
  4. Samsung Galaxy J1 Volume Button Replacement: passo 4, imagem 1 %32 Samsung Galaxy J1 Volume Button Replacement: passo 4, imagem 2 %32 Samsung Galaxy J1 Volume Button Replacement: passo 4, imagem 3 %32
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
    Pergunte ao FixBot
    Comentar
  5. Samsung Galaxy J1 Volume Button Replacement, Volume Button: passo 5, imagem 1 %32 Samsung Galaxy J1 Volume Button Replacement, Volume Button: passo 5, imagem 2 %32
    • Use the flat edge of a spudger to push the volume button out.
    • Remove the volume button.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Sean Kramer
Membro desde: 02/14/18
1.632 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S5-G4, Eyestone Spring 2018 Membro de USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 36
Ao todo: 2,534
