Ir para o conteúdo principal
Samsung Galaxy Grand Midframe Replacement
O que você precisa
  1. Samsung Galaxy Grand Midframe Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy Grand Midframe Replacement, Battery: passo 1, imagem 2 %32 Samsung Galaxy Grand Midframe Replacement, Battery: passo 1, imagem 3 %32
    • Remove the back cover of phone by lifting up on the back cover tab with the blue plastic opening tool.
    • Go around the edge of the back cover to completely remove it.
    Pergunte ao FixBot
    Comentar
  2. Samsung Galaxy Grand Midframe Replacement, Remove the battery.: passo 2, imagem 1 %32 Samsung Galaxy Grand Midframe Replacement, Remove the battery.: passo 2, imagem 2 %32 Samsung Galaxy Grand Midframe Replacement, Remove the battery.: passo 2, imagem 3 %32
    • Remove the old battery by lifting up on the thumb tab.
    • Periodically clean the brass terminals on the battery and the phone. Place a minute amount of ISO on a Q-tip and gingerly clean the connections.
    Pergunte ao FixBot
    Comentar
  3. Samsung Galaxy Grand Midframe Replacement, Midframe: passo 3, imagem 1 %32 Samsung Galaxy Grand Midframe Replacement, Midframe: passo 3, imagem 2 %32 Samsung Galaxy Grand Midframe Replacement, Midframe: passo 3, imagem 3 %32
    • Remove the nine 4mm screws screws from the midframe with a Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Samsung Galaxy Grand Midframe Replacement: passo 4, imagem 1 %32 Samsung Galaxy Grand Midframe Replacement: passo 4, imagem 2 %32
    • Wedge the blue plastic opening tool in between the front and side panel.
    • Move the blue plastic opening tool around the edges between the front and side panel.
    Pergunte ao FixBot
    Comentar
  5. Samsung Galaxy Grand Midframe Replacement: passo 5, imagem 1 %32 Samsung Galaxy Grand Midframe Replacement: passo 5, imagem 2 %32
    • Make sure that you detach the mid-frame from the inside too.
    Pergunte ao FixBot
    Comentar
Conclusão
43 outras pessoas executaram este guia.
Kyle Ruff
Membro desde: 02/04/16
6.851 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 17-3, Blackwell Winter 2016 Membro de USF Tampa, Team 17-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G3
3 Membros
Autoria de 12 guias
3Comentários do guia
anyone can tell me how to swap vibrator motor?
Athaariq Ardiansyah Ramadhani - Responder Compartilhar
I need some glue to replace the midframe after having changed it?
Andrea Rossetti - Responder Compartilhar
not necessary
yasir - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 27
Últimos 30 dias: 75
Ao todo: 13,316
