Introdução
Should the screen need to be replaced, this guide will outline how to do so.
O que você precisa
Use a T5 Torx screwdriver to remove the four 4.0 mm screws on the back of the device.
On the display, use a plastic opening tool to lift up the two ribbon cables the motherboard.
