Ir para o conteúdo principal
Samsung Galaxy Book Pro 15" Touchpad Replacement
O que você precisa
  1. Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the rubber feet: passo 1, imagem 1 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the rubber feet: passo 1, imagem 2 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the rubber feet: passo 1, imagem 3 %32
    • Before you begin, power down your laptop and unplug it.
    • There are two kinds of rubber feet along the top and bottom of the rear case. Keep track of their position as you remove them.
    • Insert an opening pick between the rubber foot and the rear case.
    • Pry up with the opening pick to release the clips securing the foot.
    • Remove the foot.
    • Repeat this procedure for the three remaining feet.
    • During reassembly, press the feet into their correct slot to reinsert them. Mismatched feet won't fit correctly.
  2. Samsung Galaxy Book Pro 15" Touchpad Replacement, Unfasten the rear case: passo 2, imagem 1 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Unfasten the rear case: passo 2, imagem 2 %32
    • Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the rear case.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3313.
  3. Samsung Galaxy Book Pro 15" Touchpad Replacement, Insert an opening pick: passo 3, imagem 1 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Insert an opening pick: passo 3, imagem 2 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Insert an opening pick: passo 3, imagem 3 %32
    • Apply a suction cup to the rear case, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear case and the frame.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy Book Pro 15" Touchpad Replacement, Release the clips: passo 4, imagem 1 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Release the clips: passo 4, imagem 2 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Release the clips: passo 4, imagem 3 %32
    • Slide the pick along the bottom edge of the rear case to release its plastic clips.
    • Repeat this process for the left and right edges, but stop before reaching the top edge.
  5. Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the rear case: passo 5, imagem 1 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the rear case: passo 5, imagem 2 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the rear case: passo 5, imagem 3 %32
    • The top edge of the rear case is lightly adhered to the frame.
    • Pull the top of the rear case away from the frame to separate the adhesive and release the remaining clips.
    • If you're having trouble separating the adhesive, use an iOpener, hair dryer, or heat gun to soften it.
    • Remove the rear case.
    • During reassembly, perform the following:
    • If you're using a using a genuine Samsung replacement rear case, be sure to peel off any adhesive liners from the rear case before securing the top edge's clips.
    • If you're reusing your rear case, you can use some pre-cut adhesive to re-adhere the top edge if your existing adhesive is no longer sticky.
    • This is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down completely before you continue working.
  6. Samsung Galaxy Book Pro 15" Touchpad Replacement, Disconnect the battery: passo 6, imagem 1 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Disconnect the battery: passo 6, imagem 2 %32
    • Insert a spudger between the frame and the bottom of the battery cable connector.
    • Pry up and disconnect the battery cable connector.
  7. Samsung Galaxy Book Pro 15" Touchpad Replacement, Unfasten the battery: passo 7, imagem 1 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Unfasten the battery: passo 7, imagem 2 %32
    • Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the battery.
    • Take care not to puncture the battery with your screwdriver—a punctured battery may leak dangerous chemicals or cause a fire.
  8. Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the battery: passo 8, imagem 1 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the battery: passo 8, imagem 2 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the battery: passo 8, imagem 3 %32
    • Lift the battery straight out of the frame and remove it.
  9. Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the tape: passo 9, imagem 1 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the tape: passo 9, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers, or your fingers, to peel back and remove the yellow tape covering the touchpad's cable connector.
  10. Samsung Galaxy Book Pro 15" Touchpad Replacement, Disconnect the touchpad: passo 10, imagem 1 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Disconnect the touchpad: passo 10, imagem 2 %32
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the touchpad cable.
  11. Samsung Galaxy Book Pro 15" Touchpad Replacement: passo 11, imagem 1 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement: passo 11, imagem 2 %32
    • Disconnect the touchpad cable by sliding it out from its socket on the touchpad.
  12. Samsung Galaxy Book Pro 15" Touchpad Replacement, Reposition the cable: passo 12, imagem 1 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Reposition the cable: passo 12, imagem 2 %32
    • The touchpad cable is lightly adhered to the touchpad.
    • Use your fingers, or tweezers, to peel the touchpad cable away from the touchpad and separate its adhesive.
  13. Samsung Galaxy Book Pro 15" Touchpad Replacement, Unfasten the touchpad: passo 13, imagem 1 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Unfasten the touchpad: passo 13, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the five 1.7 mm screws securing the touchpad.
  14. Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the touchpad: passo 14, imagem 1 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the touchpad: passo 14, imagem 2 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the touchpad: passo 14, imagem 3 %32
    • Swing the display open slightly, but keep the laptop upside-down.
    • Tilt the touchpad upwards and away from the frame.
    • Pull the touchpad towards the top of the laptop to separate it from its recess in the frame.
    • Remove the touchpad.
  15. Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the tape: passo 15, imagem 1 %32 Samsung Galaxy Book Pro 15" Touchpad Replacement, Remove the tape: passo 15, imagem 2 %32
    • Use tweezers to peel off and remove the conductive tape on the touchpad.
    • Set the tape aside. You'll reuse it during reassembly.
Conclusão
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
124.510 Reputação
Autoria de 581 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 17.288 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 37
Duração total: 717
