Introdução
Use this guide to replace a broken back cover on your Galaxy A70.
You’ll need replacement adhesive to reattach components when reassembling the device.
Ferramentas
Peças
Nenhum componente especificado.
Switch off your Galaxy A70.
Heat an iOpener and use it to soften the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the rear glass removal.
Apply a suction cup to the back of the phone, as close as possible to the center of the right edge.
Pull on the suction cup to create a gap between the rear glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the edge to the bottom right corner.
Leave the opening pick in its place to prevent the adhesive from resealing.
Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
8 outras pessoas concluíram este guia.
