Introdução
Use this guide to replace a damaged back cover on your Samsung Galaxy A53 5G.
You’ll need to replace the adhesive on the back cover when reassembling to seal the device shut. Depending on that seal, the device might lose its water protection.
You'll need replacement adhesive to complete this repair.
O que você precisa
Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the right edge of the back cover, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the top right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick at the top right edge of your phone.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Uma outra pessoa concluiu este guia.
2 comentários
Where the heck do you get one of these back pieces? No one has them.
