Ir para o conteúdo principal
Samsung Galaxy A11 Display Assembly Replacement
O que você precisa
  1. Samsung Galaxy A11 Display Assembly Replacement, Back Cover: passo 1, imagem 1 %32 Samsung Galaxy A11 Display Assembly Replacement, Back Cover: passo 1, imagem 2 %32 Samsung Galaxy A11 Display Assembly Replacement, Back Cover: passo 1, imagem 3 %32
    • Place the SIM eject tool in the hole of the sim tray.
    • Push until part of the SIM tray is pushed out.
    • Pull out the rest of the SIM tray.
    Pergunte ao FixBot
    Comentar
  2. Samsung Galaxy A11 Display Assembly Replacement: passo 2, imagem 1 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 2, imagem 2 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 2, imagem 3 %32
    • Gently pry open the area of the back cover near the SIM tray using an iFixit opening pick.
    • Gently move the pick along the gap and pry open the clips holding it together.
    • If possible, use multiple picks to prevent the back cover from closing.
    Pergunte ao FixBot
    Comentar
  3. Samsung Galaxy A11 Display Assembly Replacement: passo 3, imagem 1 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 3, imagem 2 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 3, imagem 3 %32
    • Using a hair dryer on low heat, heat the fingerprint sensor in increments of 30 seconds to loosen the surrounding adhesive.
    • Gently push the fingerprint sensor until it detaches from the back cover.
    • If needed, remove the button by prying it from the bottom of the device.
    Pergunte ao FixBot
    Comentar
  4. Samsung Galaxy A11 Display Assembly Replacement, Battery: passo 4, imagem 1 %32 Samsung Galaxy A11 Display Assembly Replacement, Battery: passo 4, imagem 2 %32 Samsung Galaxy A11 Display Assembly Replacement, Battery: passo 4, imagem 3 %32
    • Remove the three 3 mm screws from the shield using a Phillips #000 screwdriver.
    • Remove the shield from the phone.
    Pergunte ao FixBot
    Comentar
  5. Samsung Galaxy A11 Display Assembly Replacement: passo 5, imagem 1 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 5, imagem 2 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 5, imagem 3 %32
    • Using tweezers, a spudger, or your fingers, disconnect the battery press connector from the phone.
    Pergunte ao FixBot
    Comentar
  6. Samsung Galaxy A11 Display Assembly Replacement: passo 6, imagem 1 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 6, imagem 2 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 6, imagem 3 %32
    • If needed, use a hairdryer on low heat to soften the adhesive under the battery. If The Battery Is Expanded, DO NOT USE A HAIRDRYER or heat; be very careful when removing to not puncture the battery.
    • Use an iFixit pry tool to dig under the battery edge.
    • If needed, use multiple pry tools to hold the battery in place.
    • Continue to cut the adhesive under the battery until you are able to pry the battery away from the phone.
    • Remove the battery from the phone.
    Pergunte ao FixBot
    Comentar
  7. Samsung Galaxy A11 Display Assembly Replacement, Earpiece Speaker: passo 7, imagem 1 %32 Samsung Galaxy A11 Display Assembly Replacement, Earpiece Speaker: passo 7, imagem 2 %32 Samsung Galaxy A11 Display Assembly Replacement, Earpiece Speaker: passo 7, imagem 3 %32
    • Gently use tweezers to peel up the copper strip on the top right of the phone.
    Pergunte ao FixBot
    Comentar
  8. Samsung Galaxy A11 Display Assembly Replacement: passo 8, imagem 1 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 8, imagem 2 %32
    • Remove the three black 3 mm screws from the speaker cover using a Phillips #000 screwdriver.
    • Remove the cover from the phone.
    Pergunte ao FixBot
    Comentar
  9. Samsung Galaxy A11 Display Assembly Replacement: passo 9, imagem 1 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 9, imagem 2 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 9, imagem 3 %32
    • Using tweezers, carefully remove the earpiece speaker at the top of the phone.
    • When using metal tools, it is important to be gentle in order to not damage the device.
    • If needed, you can use a hair dryer to apply heat to the speaker and loosen the adhesive.
    • If needed, you may orient the tweezers to your liking, gripping the earpiece horizontally or vertically, while removing it.
    Pergunte ao FixBot
    Comentar
  10. Samsung Galaxy A11 Display Assembly Replacement, Fingerprint Sensor: passo 10, imagem 1 %32 Samsung Galaxy A11 Display Assembly Replacement, Fingerprint Sensor: passo 10, imagem 2 %32 Samsung Galaxy A11 Display Assembly Replacement, Fingerprint Sensor: passo 10, imagem 3 %32
    • Using a spudger, detach the ribbon cable connected to the fingerprint sensor.
    • Remove the fingerprint sensor from the device.
    Pergunte ao FixBot
    Comentar
  11. Samsung Galaxy A11 Display Assembly Replacement, Motherboard: passo 11, imagem 1 %32
    • Remove the two 3 mm silver screws from the top left of the device using a Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  12. Samsung Galaxy A11 Display Assembly Replacement: passo 12, imagem 1 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 12, imagem 2 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 12, imagem 3 %32
    • Using a spudger, disconnect the two ribbon cables attached to the battery slot from the motherboard.
    • Disconnect the two longer ribbon cables near the bottom right corner of the motherboard.
    • Lift these cables up slightly to reveal a gap.
    Pergunte ao FixBot
    Comentar
  13. Samsung Galaxy A11 Display Assembly Replacement: passo 13, imagem 1 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 13, imagem 2 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 13, imagem 3 %32
    • Using a spudger, gently pry the motherboard up using the corner revealed in the previous step.
    • If needed, use a metal spudger as a sturdier alternative.
    • If using a metal spudger, it is important to be gentle in order to not damage any components of the device.
    • Remove the motherboard from the device.
    Pergunte ao FixBot
    Comentar
  14. Samsung Galaxy A11 Display Assembly Replacement, Daughterboard: passo 14, imagem 1 %32 Samsung Galaxy A11 Display Assembly Replacement, Daughterboard: passo 14, imagem 2 %32 Samsung Galaxy A11 Display Assembly Replacement, Daughterboard: passo 14, imagem 3 %32
    • Remove the eight silver and black 3 mm screws from the speaker cover using a Phillips #000 screwdriver.
    • Remove the speaker cover from the device.
    Pergunte ao FixBot
    Comentar
  15. Samsung Galaxy A11 Display Assembly Replacement: passo 15, imagem 1 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 15, imagem 2 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 15, imagem 3 %32
    • Using a spudger, disconnect the antenna heads from the daughterboard.
    • Disconnect the ribbon cable from the daughterboard.
    Pergunte ao FixBot
    Comentar
  16. Samsung Galaxy A11 Display Assembly Replacement: passo 16, imagem 1 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 16, imagem 2 %32 Samsung Galaxy A11 Display Assembly Replacement: passo 16, imagem 3 %32
    • Using tweezers, gently pry the daughterboard from the device.
    Pergunte ao FixBot
    Comentar
  17. Samsung Galaxy A11 Display Assembly Replacement, Vibration Motor: passo 17, imagem 1 %32 Samsung Galaxy A11 Display Assembly Replacement, Vibration Motor: passo 17, imagem 2 %32
    • Using tweezers, remove the vibrator motor from the device.
    • If needed, you can apply heat to loosen the adhesive from the motor.
    Pergunte ao FixBot
    Comentar
  18. Samsung Galaxy A11 Display Assembly Replacement, Display Assembly: passo 18, imagem 1 %32
    • The display assembly is separated from all other components and can be replaced.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Chloe Bulloch
Membro desde: 09/04/24
789 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 82
Últimos 30 dias: 188
Ao todo: 2,730
