Ir para o conteúdo principal
Samsung Exhibit II 4G Loudspeaker Replacement
O que você precisa
  1. Samsung Exhibit II 4G Loudspeaker Replacement, Battery: passo 1, imagem 1 %32
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
    Pergunte ao FixBot
    Comentar
  2. Samsung Exhibit II 4G Loudspeaker Replacement: passo 2, imagem 1 %32
    • Insert plastic opening tool under battery.
    • Pry battery out.
    Pergunte ao FixBot
    Comentar
  3. Samsung Exhibit II 4G Loudspeaker Replacement, Top Rear Housing Cover: passo 3, imagem 1 %32
    • Pry the top cover upward to remove it from the phone.
    Pergunte ao FixBot
    Comentar
  4. Samsung Exhibit II 4G Loudspeaker Replacement: passo 4, imagem 1 %32
    • Remove the top cover.
    Pergunte ao FixBot
    Comentar
  5. Samsung Exhibit II 4G Loudspeaker Replacement: passo 5, imagem 1 %32 Samsung Exhibit II 4G Loudspeaker Replacement: passo 5, imagem 2 %32
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
    Pergunte ao FixBot
    Comentar
  6. Samsung Exhibit II 4G Loudspeaker Replacement: passo 6, imagem 1 %32 Samsung Exhibit II 4G Loudspeaker Replacement: passo 6, imagem 2 %32 Samsung Exhibit II 4G Loudspeaker Replacement: passo 6, imagem 3 %32
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
    Pergunte ao FixBot
    Comentar
  7. Samsung Exhibit II 4G Loudspeaker Replacement, Midframe: passo 7, imagem 1 %32
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
    Pergunte ao FixBot
    Comentar
  8. Samsung Exhibit II 4G Loudspeaker Replacement: passo 8, imagem 1 %32
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
    Pergunte ao FixBot
    Comentar
  9. Samsung Exhibit II 4G Loudspeaker Replacement: passo 9, imagem 1 %32
    • With plastic opening tool continue prying around the edge of the back assembly.
    Pergunte ao FixBot
    Comentar
  10. Samsung Exhibit II 4G Loudspeaker Replacement: passo 10, imagem 1 %32
    • Pull back panel assembly away from main body.
    Pergunte ao FixBot
    Comentar
  11. Samsung Exhibit II 4G Loudspeaker Replacement, Loudspeaker: passo 11, imagem 1 %32 Samsung Exhibit II 4G Loudspeaker Replacement, Loudspeaker: passo 11, imagem 2 %32 Samsung Exhibit II 4G Loudspeaker Replacement, Loudspeaker: passo 11, imagem 3 %32
    • Position Back Panel Assembly so the internal Loudspeaker unit is facing up.
    • With your index fingers and thumbs, grasp the Back Panel Assembly near the Loudspeaker.
    • Twist your palms inward to apply pressure against your index fingers.
    • The Loudspeaker will easily pop out.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
David R
Membro desde: 07/20/15
1.152 Reputação
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 21
Ao todo: 576
