Ir para o conteúdo principal
Samsung Epix Keyboard Replacement
O que você precisa
  1. Samsung Epix Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Just below the phone's camera, press the button and hold it
    • While the button is held down, slide the back panel off to remove it completely.
    Pergunte ao FixBot
    Comentar
  2. Samsung Epix Keyboard Replacement: passo 2, imagem 1 %32
    • Grasp the bottom corners of the battery with two fingers and gently lift.
    • Gently lift the battery and remove it from the phone.
    Pergunte ao FixBot
    Comentar
  3. Samsung Epix Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Using a plastic prying tool, remove the screw cover in the top left corner of the phone by lifting it up.
    • Be gentle
    Pergunte ao FixBot
    Comentar
  4. Samsung Epix Keyboard Replacement: passo 4, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the six screws on the back of the phone.
    • Three of the screws are evenly spaced on the left and right side on the back of the phone.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
    Pergunte ao FixBot
    Comentar
  5. Samsung Epix Keyboard Replacement: passo 5, imagem 1 %32 Samsung Epix Keyboard Replacement: passo 5, imagem 2 %32
    • Insert the prying tool into the seam on the side of the phone and turn it slightly. Do this for each of the eight clips to unhook them
    • There are three clips on each side and two at the bottom of the phone.
    Pergunte ao FixBot
    Comentar
  6. Samsung Epix Keyboard Replacement: passo 6, imagem 1 %32
    • Once all eight of the clips have been unhooked, lift the back panel gently off of the phone.
    • Be careful and do not attempt to remove the front panel. It is still connected to the phone's chassis by a ribbon cable which is located in the bottom right side of the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Samsung Epix Keyboard Replacement: passo 7, imagem 1 %32
    • Using the plastic prying tool, unlatch the ribbon cable located in the lower right corner of the motherboard.
    • Carefully disconnect the ribbon cable.
    Pergunte ao FixBot
    Comentar
  8. Samsung Epix Keyboard Replacement: passo 8, imagem 1 %32
    • Gently lift and remove the front faceplate
    • Exercise caution
    Pergunte ao FixBot
    Comentar
  9. Samsung Epix Keyboard Replacement: passo 9, imagem 1 %32
    • Grasp the rubber keyboard in the corner with your fingers and lift to remove it.
    • Lift it and gently take it out the frame to remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
Chris
Membro desde: 04/20/11
32 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-15, Regan Spring 2011 Membro de Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 40
Ao todo: 2,025
