Ir para o conteúdo principal
Samsung Epic 4G Power Button Replacement
O que você precisa
  1. Samsung Epic 4G Power Button Replacement, Phone Case: passo 1, imagem 1 %32
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
    Pergunte ao FixBot
    Comentar
  2. Samsung Epic 4G Power Button Replacement: passo 2, imagem 1 %32
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
    Pergunte ao FixBot
    Comentar
  3. Samsung Epic 4G Power Button Replacement, Battery: passo 3, imagem 1 %32
    • Remove the battery from the device by pulling the battery edge upwards.
    Pergunte ao FixBot
    Comentar
  4. Samsung Epic 4G Power Button Replacement, Removing the Memory Card:: passo 4, imagem 1 %32
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
    Pergunte ao FixBot
    Comentar
  5. Samsung Epic 4G Power Button Replacement, Removing the Back Housing: passo 5, imagem 1 %32 Samsung Epic 4G Power Button Replacement, Removing the Back Housing: passo 5, imagem 2 %32
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
    Pergunte ao FixBot
    Comentar
  6. Samsung Epic 4G Power Button Replacement, Removing the Power Button: passo 6, imagem 1 %32 Samsung Epic 4G Power Button Replacement, Removing the Power Button: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 24-25, Regan Fall 2012 Membro de Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 36
Ao todo: 2,749
