Ir para o conteúdo principal
Samsung Epic 4G Micro USB Port Replacement
O que você precisa
  1. Samsung Epic 4G Micro USB Port Replacement, Phone Case: passo 1, imagem 1 %32
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
    Pergunte ao FixBot
    Comentar
  2. Samsung Epic 4G Micro USB Port Replacement: passo 2, imagem 1 %32
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
    Pergunte ao FixBot
    Comentar
  3. Samsung Epic 4G Micro USB Port Replacement, Battery: passo 3, imagem 1 %32
    • Remove the battery from the device by pulling the battery edge upwards.
    Pergunte ao FixBot
    Comentar
  4. Samsung Epic 4G Micro USB Port Replacement, Removing the Memory Card:: passo 4, imagem 1 %32
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
    Pergunte ao FixBot
    Comentar
  5. Samsung Epic 4G Micro USB Port Replacement, Removing the Back Housing: passo 5, imagem 1 %32 Samsung Epic 4G Micro USB Port Replacement, Removing the Back Housing: passo 5, imagem 2 %32
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
    Pergunte ao FixBot
    Comentar
  6. Samsung Epic 4G Micro USB Port Replacement, Removing the Power Button: passo 6, imagem 1 %32 Samsung Epic 4G Micro USB Port Replacement, Removing the Power Button: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
    Pergunte ao FixBot
    Comentar
  7. Samsung Epic 4G Micro USB Port Replacement, Micro USB Port: passo 7, imagem 1 %32
    • Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
    • Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
    • Do not rip the white cables out of the device.
    Pergunte ao FixBot
    Comentar
  8. Samsung Epic 4G Micro USB Port Replacement, Removing the Antenna Assembly: passo 8, imagem 1 %32 Samsung Epic 4G Micro USB Port Replacement, Removing the Antenna Assembly: passo 8, imagem 2 %32
    • Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver.
    • Snap the antenna assembly out of the device gently using your fingers.
    Pergunte ao FixBot
    Comentar
  9. Samsung Epic 4G Micro USB Port Replacement, Removing the Flex Cable: passo 9, imagem 1 %32 Samsung Epic 4G Micro USB Port Replacement, Removing the Flex Cable: passo 9, imagem 2 %32
    • Pry the flex cable from the top of the phone by carefully using a nylon spudger.
    • Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
    Pergunte ao FixBot
    Comentar
  10. Samsung Epic 4G Micro USB Port Replacement: passo 10, imagem 1 %32
    • Lift and remove the motherboard from the device.
    • The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 24-25, Regan Fall 2012 Membro de Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 Membros
Autoria de 14 guias
1Comentário do guia
My phone doesn’t have a memory card. At least, not that I can see. What should I do?
Joshua Campbell - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 29
Ao todo: 2,844
