Ir para o conteúdo principal
Samsung Droid Charge Screen Replacement
O que você precisa
  1. Samsung Droid Charge Screen Replacement, Rear Cover: passo 1, imagem 1 %32
    • Open up the back case on the phone from the groove in the bottom of the phone.
    • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
    Pergunte ao FixBot
    Comentar
  2. Samsung Droid Charge Screen Replacement, Battery: passo 2, imagem 1 %32
    • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
    Pergunte ao FixBot
    Comentar
  3. Samsung Droid Charge Screen Replacement, microSD: passo 3, imagem 1 %32
    • Push the SD card further into its metal slot until you hear a click.
    • Release the card, and it should automatically eject itself.
    • Remove the SD card.
    Pergunte ao FixBot
    Comentar
  4. Samsung Droid Charge Screen Replacement, SIM Card: passo 4, imagem 1 %32
    • Slide the SIM card out of its casing by pushing on it and sliding it upward.
    Pergunte ao FixBot
    Comentar
  5. Samsung Droid Charge Screen Replacement, Screen: passo 5, imagem 1 %32
    • Locate the 7 small black screws located around the edge of the phone under the battery cover.
    • With a small Philips head screwdriver, remove each of the screws and place them in a secure location.
    Pergunte ao FixBot
    Comentar
  6. Samsung Droid Charge Screen Replacement: passo 6, imagem 1 %32
    • Locate your pry tool.
    • Insert the pry tool into the plastic edge that runs along the sides of the phone. Doing so will allow you to remove part of the back casing.
    • Use a prying motion to lift the casing up.
    • Repeat this motion all around the screen edge until the casing pops off.
    Pergunte ao FixBot
    Comentar
  7. Samsung Droid Charge Screen Replacement: passo 7, imagem 1 %32
    • Release the one pop connector for the motherboard located on the right.
    • Release the volume button flex cable on the right.
    • Release the power button flex cable on the right.
    • Now the motherboard can be removed. Simply lift out the motherboard and set aside.
    Pergunte ao FixBot
    Comentar
  8. Samsung Droid Charge Screen Replacement: passo 8, imagem 1 %32 Samsung Droid Charge Screen Replacement: passo 8, imagem 2 %32 Samsung Droid Charge Screen Replacement: passo 8, imagem 3 %32
    • Using a hairdryer or heat gun, warm the phone. Doing so will warm the adhesive holding the screen in place, allowing us to continue disassembling the device.
    • Use the pry tool to pry the screen off the casing. You may need to use force to overcome the adhesive.
    • Work carefully to prevent damage to the phone.
    Pergunte ao FixBot
    Comentar
  9. Samsung Droid Charge Screen Replacement: passo 9, imagem 1 %32
    • You can now swap out the old screen for your new one.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
6 outras pessoas executaram este guia.
Luke Gordon
Membro desde: 09/26/12
199 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 15-44, Forte Fall 2012 Membro de Cal Poly, Team 15-44, Forte Fall 2012
CPSU-FORTE-F12S15G44
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 27
Ao todo: 3,467
