Ir para o conteúdo principal
Samsung DV300F Front LCD Screen Replacement
O que você precisa
    1. Samsung DV300F Front LCD Screen Replacement, Front and Rear Casing: passo 1, imagem 1 %32 Samsung DV300F Front LCD Screen Replacement, Front and Rear Casing: passo 1, imagem 2 %32 Samsung DV300F Front LCD Screen Replacement, Front and Rear Casing: passo 1, imagem 3 %32
      • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
      • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
      • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Samsung DV300F Front LCD Screen Replacement: passo 2, imagem 1 %32 Samsung DV300F Front LCD Screen Replacement: passo 2, imagem 2 %32
      • Remove the back case of the camera carefully.
      Pergunte ao FixBot
      Comentar
    3. Samsung DV300F Front LCD Screen Replacement: passo 3, imagem 1 %32 Samsung DV300F Front LCD Screen Replacement: passo 3, imagem 2 %32 Samsung DV300F Front LCD Screen Replacement: passo 3, imagem 3 %32
      • Remove the front case of the camera.
      • Remove the front LCD screen from the front case next to the lens.
      Pergunte ao FixBot
      Comentar
    1. Samsung DV300F Front LCD Screen Replacement, Back Button Control: passo 4, imagem 1 %32 Samsung DV300F Front LCD Screen Replacement, Back Button Control: passo 4, imagem 2 %32
      • Remove the blue button control from its position next to the LCD screen.
      • Pull the ribbon cable to disconnect the blue button control from the camera.
      Pergunte ao FixBot
      Comentar
    1. Samsung DV300F Front LCD Screen Replacement, Back LCD Screen: passo 5, imagem 1 %32
      • Remove the back LCD screen from its place carefully.
      Pergunte ao FixBot
      Comentar
    2. Samsung DV300F Front LCD Screen Replacement: passo 6, imagem 1 %32 Samsung DV300F Front LCD Screen Replacement: passo 6, imagem 2 %32
      • Flip the black tab where the back LCD screen connects to the circuit board.
      • Pull the tape connection to disconnect the back LCD screen from the circuit board.
      Pergunte ao FixBot
      Comentar
    1. Samsung DV300F Front LCD Screen Replacement, Front LCD Screen: passo 7, imagem 1 %32 Samsung DV300F Front LCD Screen Replacement, Front LCD Screen: passo 7, imagem 2 %32
      • Unscrew the 3 silver 4.5 mm screws from the circuit board using a Phillips #0 screwdriver.
      • Remove the circuit board cover.
      Pergunte ao FixBot
      Comentar
    2. Samsung DV300F Front LCD Screen Replacement: passo 8, imagem 1 %32 Samsung DV300F Front LCD Screen Replacement: passo 8, imagem 2 %32 Samsung DV300F Front LCD Screen Replacement: passo 8, imagem 3 %32
      • Flip the black tab where the front LCD screen connects to the circuit board.
      • Pull the tape connection to disconnect the front LCD screen from the circuit board.
      • You can do this easily with your fingers.
      • Remove the front LCD screen from the front of the camera.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Baylor, Team 5-10, Williams Spring 2015 Membro de Baylor, Team 5-10, Williams Spring 2015
BU-WILLIAMS-S15S5G10
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 47
Ao todo: 1,476
