Ir para o conteúdo principal
Samsung Chromebook Plus Battery Replacement
O que você precisa
  1. Samsung Chromebook Plus Battery Replacement, Removing back panel screws: passo 1, imagem 1 %32
    • Remove the 8 PHILIPS#0 screws
  2. Samsung Chromebook Plus Battery Replacement, Removing back panel: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Stick a plastic card (or fingernail) into the gap between panel and the body. Then lift the panel up (long side with speakers closest).
  3. Samsung Chromebook Plus Battery Replacement, Removing battery screws: passo 3, imagem 1 %32
    • Use your PHILIPS#0 and remove the 4 screws
  4. Samsung Chromebook Plus Battery Replacement, Removing the battery: passo 4, imagem 1 %32
    • Lift battery from bottom side first (marked with red line)
  5. Samsung Chromebook Plus Battery Replacement, Finally detaching the battery: passo 5, imagem 1 %32
    • Detach battery cable grabbing the side and pulling the cable upward.
  6. Samsung Chromebook Plus Battery Replacement, Inserting the new battery: passo 6, imagem 1 %32
    • Insert the battery and push the plug into the socket downward.
  7. Samsung Chromebook Plus Battery Replacement, Re-inserting the screws: passo 7, imagem 1 %32
    • Re-insert the screws in the holes circled red (on this image), which is where you removed them previously.
  8. Samsung Chromebook Plus Battery Replacement, The back panel gets re-inserted: passo 8, imagem 1 %32
    • Insert the hinge-side middle screw (must be done first otherwise casing may bulge) and insert rest of panel. On the hinge side, press down on the sides (if there is bulging) until you hear it snap. Insert the two other hinge-side screws (marked with orange on image). After that, insert the other 5 screws (yellow).
Conclusão
To reassemble your device, skip steps 1-5.
7 outras pessoas executaram este guia.
Evan Elm
Membro desde: 12/31/17
1.023 Reputação
Autoria de 3 guias
Equipe
Kid fixers Membro de Kid fixers
Community
Membros da 156
Autoria de 292 guias
6 comentários
Great repair guide. Nice to see how easy it is to replace battery.
N ick - Responder
Does anyone know where you can get a replacement battery?
Stanley Fujimoto - Responder
Sadly no, I have no idea, chromebookparts.com doesn't have a part either, haven't found one anywhere yet
Evan Elm -
I managed to find a replacement part, see the parts section at the top of the guide :)
Evan Elm -
thanks for finding the battery part! Awesome job!
JT Cen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 48
Duração total: 6,817
