Ir para o conteúdo principal
Samsung Captivate Camera Assembly Replacement
O que você precisa
  1. Samsung Captivate Camera Assembly Replacement, Battery: passo 1, imagem 1 %32
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
    Pergunte ao FixBot
    Comentar
  2. Samsung Captivate Camera Assembly Replacement: passo 2, imagem 1 %32
    • Place your finger on the bottom of the battery and lift to remove.
    Pergunte ao FixBot
    Comentar
  3. Samsung Captivate Camera Assembly Replacement: passo 3, imagem 1 %32
    • Replace the old battery with the new one.
    Pergunte ao FixBot
    Comentar
  4. Samsung Captivate Camera Assembly Replacement, Rear Case: passo 4, imagem 1 %32
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
    Pergunte ao FixBot
    Comentar
  5. Samsung Captivate Camera Assembly Replacement: passo 5, imagem 1 %32
    • Remove the six 4.5mm #000 Phillips screws.
    Pergunte ao FixBot
    Comentar
  6. Samsung Captivate Camera Assembly Replacement: passo 6, imagem 1 %32 Samsung Captivate Camera Assembly Replacement: passo 6, imagem 2 %32 Samsung Captivate Camera Assembly Replacement: passo 6, imagem 3 %32
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
    Pergunte ao FixBot
    Comentar
  7. Samsung Captivate Camera Assembly Replacement: passo 7, imagem 1 %32
    • Separate the rear case from the phone.
    Pergunte ao FixBot
    Comentar
  8. Samsung Captivate Camera Assembly Replacement, Camera Assembly: passo 8, imagem 1 %32
    • Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
    Pergunte ao FixBot
    Comentar
  9. Samsung Captivate Camera Assembly Replacement: passo 9, imagem 1 %32
    • Gently lift the camera assembly out of the plastic housing.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Drew Bentz
Membro desde: 09/22/11
565 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 20-25, Maness Fall 2011 Membro de Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 Membros
Autoria de 18 guias
2Comentários do guia
Is this for the front facing camera
tracy mann - Responder Compartilhar
No, this is for the rear facing camera. The Samsung Captivate does not have a front facing camera.
Will Budney - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 35
Ao todo: 2,792
