Ir para o conteúdo principal
Samsung Brightside Speaker Module Replacement
O que você precisa
  1. Samsung Brightside Speaker Module Replacement, Speaker Module: passo 1, imagem 1 %32 Samsung Brightside Speaker Module Replacement, Speaker Module: passo 1, imagem 2 %32 Samsung Brightside Speaker Module Replacement, Speaker Module: passo 1, imagem 3 %32
    • Here is the Samsung SCH-U380 Brightside
    • Turn it over to gain access to the battery.
    • Remove the backcover by simply pulling it off the phone from the top down
    Pergunte ao FixBot
  2. Samsung Brightside Speaker Module Replacement: passo 2, imagem 1 %32 Samsung Brightside Speaker Module Replacement: passo 2, imagem 2 %32 Samsung Brightside Speaker Module Replacement: passo 2, imagem 3 %32
    • Remove the battery
    • Remove the six Phillips screws from the back frame
    • All six screws are identical M1.5X3
    Pergunte ao FixBot
  3. Samsung Brightside Speaker Module Replacement: passo 3, imagem 1 %32 Samsung Brightside Speaker Module Replacement: passo 3, imagem 2 %32 Samsung Brightside Speaker Module Replacement: passo 3, imagem 3 %32
    • Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips
    • Continue to slide the tool along the slot until you feel the plastic locks disengage
    • Once all locks have released, the bottom frame can simply be removed.
    Pergunte ao FixBot
  4. Samsung Brightside Speaker Module Replacement: passo 4, imagem 1 %32 Samsung Brightside Speaker Module Replacement: passo 4, imagem 2 %32 Samsung Brightside Speaker Module Replacement: passo 4, imagem 3 %32
    • Remove the two Phillips screws from the EMI shield.
    • Both screws are identical M1.5X2
    • Remove the EMI shield
    Pergunte ao FixBot
  5. Samsung Brightside Speaker Module Replacement: passo 5, imagem 1 %32 Samsung Brightside Speaker Module Replacement: passo 5, imagem 2 %32 Samsung Brightside Speaker Module Replacement: passo 5, imagem 3 %32
    • Detach the LCD connector.
    • Remove the logic board
    • This is the speaker module. In the center is the camera, but it is not part of the module.
    Pergunte ao FixBot
  6. Samsung Brightside Speaker Module Replacement: passo 6, imagem 1 %32 Samsung Brightside Speaker Module Replacement: passo 6, imagem 2 %32 Samsung Brightside Speaker Module Replacement: passo 6, imagem 3 %32
    • turn the logic board over. The speaker module is held in place
    • by one Phillips screw
    • and two clips
    • Remove the Phillips screw.
    • It is a M1X2 Phillips screw
    • Next disengage one of the clips by simply applying some sideways pressure with your fingernail. This will loosen the module.
    Pergunte ao FixBot
  7. Samsung Brightside Speaker Module Replacement: passo 7, imagem 1 %32 Samsung Brightside Speaker Module Replacement: passo 7, imagem 2 %32
    • Turn the logic board around. With the speaker module loose, simply lift it off the board.
    • Speaker module removed.
    • Camera
    • and audio jack
    • are not part of this module and will remain on the board.
    Pergunte ao FixBot
Conclusão
oldturkey03
Membro desde: 09/29/10
854.808 Reputação
Autoria de 123 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 76
Ao todo: 1,268
