Ir para o conteúdo principal
Samsung ATIV Book 9 Plus Keys Replacement
O que você precisa
  1. Samsung ATIV Book 9 Plus Keys Replacement, Keys: passo 1, imagem 1 %32 Samsung ATIV Book 9 Plus Keys Replacement, Keys: passo 1, imagem 2 %32
    • Open your laptop so your keyboard is facing you and is easily accessible.
    Pergunte ao FixBot
    Comentar
  2. Samsung ATIV Book 9 Plus Keys Replacement: passo 2, imagem 1 %32 Samsung ATIV Book 9 Plus Keys Replacement: passo 2, imagem 2 %32 Samsung ATIV Book 9 Plus Keys Replacement: passo 2, imagem 3 %32
    • Using a plastic opening tool, carefully push the thin tip under the key.
    Pergunte ao FixBot
    Comentar
  3. Samsung ATIV Book 9 Plus Keys Replacement: passo 3, imagem 1 %32 Samsung ATIV Book 9 Plus Keys Replacement: passo 3, imagem 2 %32
    • Pivot the tool upwards. This should pry the key away from the keyboard.
    • Hearing some snapping sounds should be normal as the key lifts away from its attachments.
    • Continue lifting the tool until the key comes away completely or gently pull the key off. Repeat for other keys as needed.
    • Be gentle, as the attachments may accidentally break with rough handling.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
unknown
Membro desde: 03/20/15
261 Reputação
Autoria de 1 guia
Equipe
Baylor, Team 2-3, Grigsby Spring 2015 Membro de Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 27
Ao todo: 6,570
