Ir para o conteúdo principal
Samsung ATIV Book 9 Plus Battery Replacement
O que você precisa
  1. Samsung ATIV Book 9 Plus Battery Replacement, Back Cover: passo 1, imagem 1 %32 Samsung ATIV Book 9 Plus Battery Replacement, Back Cover: passo 1, imagem 2 %32 Samsung ATIV Book 9 Plus Battery Replacement, Back Cover: passo 1, imagem 3 %32
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
    Pergunte ao FixBot
    Comentar
  2. Samsung ATIV Book 9 Plus Battery Replacement: passo 2, imagem 1 %32
    • Lift the cover to reveal the interior of the laptop.
    Pergunte ao FixBot
    Comentar
  3. Samsung ATIV Book 9 Plus Battery Replacement, Battery: passo 3, imagem 1 %32 Samsung ATIV Book 9 Plus Battery Replacement, Battery: passo 3, imagem 2 %32 Samsung ATIV Book 9 Plus Battery Replacement, Battery: passo 3, imagem 3 %32
    • Unscrew the four 4.55 mm Phillips #000 screws on the edges of the battery.
    Pergunte ao FixBot
    Comentar
  4. Samsung ATIV Book 9 Plus Battery Replacement: passo 4, imagem 1 %32 Samsung ATIV Book 9 Plus Battery Replacement: passo 4, imagem 2 %32
    • Lift to remove the battery from the laptop.
    • Place in the new battery to match the edges located on the laptop. Push on the top edge of the battery to secure it in place.
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Nidhi Patel
Membro desde: 03/20/15
271 Reputação
Autoria de 1 guia
Equipe
Baylor, Team 2-3, Grigsby Spring 2015 Membro de Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
4 Membros
Autoria de 4 guias
4Comentários do guia
Could you point to the RAM modules in the pictures please
rerof - Responder Compartilhar
http://www.myfixguide.com/manual/samsung...
There are no RAM modules. They are welded in the mother board.
Best regards!
Raul Lacavex - Responder Compartilhar
any updated amazon product?
amitshalem - Responder Compartilhar
I just bought and installed this battery from Amazon: https://www.amazon.com/gp/product/B07NW7...
Mark Wolfman - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 44
Ao todo: 13,241
