Ir para o conteúdo principal
Samsung 27E510C HDMI Port Replacement
O que você precisa
  1. Samsung 27E510C HDMI Port Replacement, Back Panel: passo 1, imagem 1 %32 Samsung 27E510C HDMI Port Replacement, Back Panel: passo 1, imagem 2 %32 Samsung 27E510C HDMI Port Replacement, Back Panel: passo 1, imagem 3 %32
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C HDMI Port Replacement: passo 2, imagem 1 %32 Samsung 27E510C HDMI Port Replacement: passo 2, imagem 2 %32
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
  3. Samsung 27E510C HDMI Port Replacement, Motherboard: passo 3, imagem 1 %32
    • Remove the navigation button connector by pulling while holding down its thumb tab.
  4. Samsung 27E510C HDMI Port Replacement: passo 4, imagem 1 %32
    • Remove the screen connector by gripping its sides and gently pulling while wiggling back and forth.
  5. Samsung 27E510C HDMI Port Replacement: passo 5, imagem 1 %32 Samsung 27E510C HDMI Port Replacement: passo 5, imagem 2 %32 Samsung 27E510C HDMI Port Replacement: passo 5, imagem 3 %32
    • For the ribbon cable, Lift the tab from the side facing the inside of the mother board with your fingernail or a spudger.
    • Remove the cable by pulling while lifting slightly.
    • If the cable does not come out easily, than the secure tab may not be fully opened.
  6. Samsung 27E510C HDMI Port Replacement: passo 6, imagem 1 %32 Samsung 27E510C HDMI Port Replacement: passo 6, imagem 2 %32 Samsung 27E510C HDMI Port Replacement: passo 6, imagem 3 %32
    • Remove each of the 5mm length screws attaching the motherboard to the body of the monitor using a #1 Phillips head screwdriver.
  7. Samsung 27E510C HDMI Port Replacement: passo 7, imagem 1 %32 Samsung 27E510C HDMI Port Replacement: passo 7, imagem 2 %32
    • Using both hands, lift the board off of the monitor body by the motherboards base.
  8. Samsung 27E510C HDMI Port Replacement, HDMI Port: passo 8, imagem 1 %32
    • Gently place the motherboard on a static free surface.
    • It is imperative that this is done on a static free surface, as any discharge of static electricity can 'fry' your motherboard and render it useless.
  9. Samsung 27E510C HDMI Port Replacement: passo 9, imagem 1 %32 Samsung 27E510C HDMI Port Replacement: passo 9, imagem 2 %32
    • Desolder each of the indicated leads located on the back of the motherboard.
    • The HDMI Port should fall off of the board after all solder is removed.
  10. Samsung 27E510C HDMI Port Replacement: passo 10, imagem 1 %32
    • If the HDMI Port does not fall off the motherboard, try tugging it with your hand.
    • The HDMI Port may be too hot to touch right after desoldering.
    • Excessive tugging ccould damage the motherboard.
Conclusão
To reassemble your device, follow these instructions in reverse order. The process of soldering the components back onto the board is similar to desoldering, the difference is that instead of using the Solder Wick, to suck up the solder, you're using Solder Wire to add solder.
Uma outra pessoa concluiu este guia.
Jesus Blanco
Membro desde: 09/27/17
240 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S9-G1, Banghart Fall 2017 Membro de Cal Poly, Team S9-G1, Banghart Fall 2017
CPSU-BANGHART-F17S9G1
Membros da 6
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 69
Duração total: 6,222
