O que você precisa
Remove the foam pad by pulling up on the foam until it clears the groove.
Working around the foam, carefully slip it off to reveal the screws.
Remove the 4 screws holding the speaker enclosure to the main body.
Desolder the speaker to fully remove it.
Desolder the mic and speaker conncetions
Desolder the battery connector.
Remove one Phillips screw, holding down the board
The board is also held in by clips, so use a prying tool or just fingers to pull upp on the board to release it.
You successfully removed the main board.
You can see the damaged USB connector
Apply Kapton tape to ensure protect the plastic components like, switches and the jack conncetor.
Apply flux to the top pins and the mounting pins (underside) to help solder flow.
4 outras pessoas executaram este guia.
4 comentários
thank you for an excellent guide. I am a volunteer at our local repair cafe where we try to repair things, free of charge, for residents and so avoid the item ending up in landfill. I have had a pair of the Sony WH -CH700N headphones in and need to replace the charging port. Sony will not supply. where can I get the right one? do you have a prat number? any help appreciated. many thanks Roger H
Hi @rogerhutton
I found these to be a suitable replacement and fairly inexpensive:
https://www.ebay.co.uk/itm/132334638219
https://www.ebay.co.uk/itm/142512274587
Hope it helps!
Kris
Thank you very much Kris. Ordered and fitted and a very happy resident to have them fixed at a cost of £2.50! Thank you again on his behalf and from the volunteers at the Dorking Repair cafe. all the best Roger H
