Ir para o conteúdo principal
SG 552-1 Commando Trigger Replacement
O que você precisa
    1. SG 552-1 Commando Trigger Replacement, Gearbox: passo 1, imagem 1 %32 SG 552-1 Commando Trigger Replacement, Gearbox: passo 1, imagem 2 %32
      • Using a flathead screwdriver, remove the pin holding the hand guard in place.
      • To remove this, turn the pin clockwise and push it through at the same time.
      • Remove the hand guard.
      Pergunte ao FixBot
      Comentar
    2. SG 552-1 Commando Trigger Replacement: passo 2, imagem 1 %32 SG 552-1 Commando Trigger Replacement: passo 2, imagem 2 %32
      • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun.
      • There should be four total.
      Pergunte ao FixBot
      Comentar
    3. SG 552-1 Commando Trigger Replacement: passo 3, imagem 1 %32 SG 552-1 Commando Trigger Replacement: passo 3, imagem 2 %32
      • Turn the gun over so that you are facing the bottom of the gun.
      • Using a Phillips #1 screwdriver, remove the following screws:
      • Remove the 8mm screw that is located directly underneath the cocking lever.
      • Remove the 8mm screw located beside the screw you just removed.
      Pergunte ao FixBot
      Comentar
    4. SG 552-1 Commando Trigger Replacement: passo 4, imagem 1 %32 SG 552-1 Commando Trigger Replacement: passo 4, imagem 2 %32
      • Carefully tug on the tip of the gun and pull the barrel and its cover out.
      Pergunte ao FixBot
      Comentar
    5. SG 552-1 Commando Trigger Replacement: passo 5, imagem 1 %32 SG 552-1 Commando Trigger Replacement: passo 5, imagem 2 %32 SG 552-1 Commando Trigger Replacement: passo 5, imagem 3 %32
      • Locate the hand grip.
      • Using a Phillips #0 screwdriver, remove the two 6mm screws at the bottom of the hand grip.
      • Slide the cover off.
      Pergunte ao FixBot
      Comentar
    6. SG 552-1 Commando Trigger Replacement: passo 6, imagem 1 %32 SG 552-1 Commando Trigger Replacement: passo 6, imagem 2 %32
      • Pull the motor out of the hand grip.
      • Using a Phillips #1 screwdriver, remove the two 5mm screws inside of the hand grip.
      Pergunte ao FixBot
      Comentar
    7. SG 552-1 Commando Trigger Replacement: passo 7, imagem 1 %32 SG 552-1 Commando Trigger Replacement: passo 7, imagem 2 %32
      • Locate the pin holding the folding stock in place.
      • Using an allen wrench or something small, carefully push the pin out.
      Pergunte ao FixBot
      Comentar
    8. SG 552-1 Commando Trigger Replacement: passo 8, imagem 1 %32 SG 552-1 Commando Trigger Replacement: passo 8, imagem 2 %32
      • Using a Phillips #1 screwdriver, remove the 20mm screw behind the folding stock and above the gearbox.
      • Remove the cover that was held on by the screw.
      Pergunte ao FixBot
      Comentar
    9. SG 552-1 Commando Trigger Replacement: passo 9, imagem 1 %32 SG 552-1 Commando Trigger Replacement: passo 9, imagem 2 %32 SG 552-1 Commando Trigger Replacement: passo 9, imagem 3 %32
      • Using a flathead screwdriver, remove the two 5mm screws beside the safety switch on both sides of the gun.
      • Slide off the piece that was held on by those screws.
      Pergunte ao FixBot
      Comentar
    10. SG 552-1 Commando Trigger Replacement: passo 10, imagem 1 %32 SG 552-1 Commando Trigger Replacement: passo 10, imagem 2 %32
      • Using a small allen wrench, carefully unscrew the screws holding the safety switch in place on both sides of the gun.
      • The screws do not have to be taken out all the way, just slightly loosen them until you are able to pull the switch off.
      Pergunte ao FixBot
      Comentar
    11. SG 552-1 Commando Trigger Replacement: passo 11, imagem 1 %32 SG 552-1 Commando Trigger Replacement: passo 11, imagem 2 %32
      • Using a Phillips #0 screwdriver, remove the two 6mm screws that were underneath the safety switch on both sides of the gun.
      • Carefully remove the pieces that were held on by the screws.
      Pergunte ao FixBot
      Comentar
    12. SG 552-1 Commando Trigger Replacement: passo 12, imagem 1 %32 SG 552-1 Commando Trigger Replacement: passo 12, imagem 2 %32 SG 552-1 Commando Trigger Replacement: passo 12, imagem 3 %32
      • Pull apart the cover when pulling the gearbox out.
      • Pull the gearbox out.
      • The gears will fall out when taking the gearbox out. Careful not to lose them.
      Pergunte ao FixBot
      Comentar
    1. SG 552-1 Commando Trigger Replacement, Trigger: passo 13, imagem 1 %32 SG 552-1 Commando Trigger Replacement, Trigger: passo 13, imagem 2 %32
      • Remove these four 15mm screws.
      • Remove this single 8mm screw.
      • Using a Phillips #0 screwdriver, remove the following screws:
      • Remove this single 14mm screw.
      • Remove this single 3mm screw.
      • Detach the pieces unscrewed from the gearbox.
      Pergunte ao FixBot
      Comentar
    2. SG 552-1 Commando Trigger Replacement: passo 14, imagem 1 %32 SG 552-1 Commando Trigger Replacement: passo 14, imagem 2 %32
      • Remove the cover over the trigger.
      • Remove the safety piece.
      • Using a Phillips #1 screwdriver, remove the 18mm screw beside the trigger.
      Pergunte ao FixBot
      Comentar
    3. SG 552-1 Commando Trigger Replacement: passo 15, imagem 1 %32 SG 552-1 Commando Trigger Replacement: passo 15, imagem 2 %32
      • Remove the metal piece.
      • Removal of this piece will permanently damage the metal piece.
      • Remove the cover for the gearbox.
      Pergunte ao FixBot
      Comentar
    4. SG 552-1 Commando Trigger Replacement: passo 16, imagem 1 %32
      • Pull the trigger off the gearbox.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Anika Morris
Membro desde: 10/05/12
1 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 18-41, Regan Fall 2012 Membro de Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 33
Ao todo: 2,067
