Ir para o conteúdo principal
SG 552-1 Commando Barrel Replacement
O que você precisa
    1. SG 552-1 Commando Barrel Replacement, Barrel: passo 1, imagem 1 %32 SG 552-1 Commando Barrel Replacement, Barrel: passo 1, imagem 2 %32
      • Using a flathead screwdriver, remove the pin holding the hand guard in place.
      • To remove this, turn the pin clockwise and push it through at the same time.
      • Pull the hand guard off.
      Pergunte ao FixBot
      Comentar
    2. SG 552-1 Commando Barrel Replacement: passo 2, imagem 1 %32 SG 552-1 Commando Barrel Replacement: passo 2, imagem 2 %32
      • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun. There should be four total.
      Pergunte ao FixBot
      Comentar
    3. SG 552-1 Commando Barrel Replacement: passo 3, imagem 1 %32 SG 552-1 Commando Barrel Replacement: passo 3, imagem 2 %32
      • Locate the button to fold over the folding stock and fold over the folding stock.
      • Using a Phillips #1 screwdriver, remove the 20mm screw located behind the folding stock.
      Pergunte ao FixBot
      Comentar
    4. SG 552-1 Commando Barrel Replacement: passo 4, imagem 1 %32 SG 552-1 Commando Barrel Replacement: passo 4, imagem 2 %32
      • Turn the gun over so that you are facing the bottom of the gun.
      • Using a Phillips #1 screwdriver, remove the following screws:
      • Remove the 8mm screw located directly underneath the cocking lever.
      • Remove the 8mm screw beside the one you just removed.
      Pergunte ao FixBot
      Comentar
    5. SG 552-1 Commando Barrel Replacement: passo 5, imagem 1 %32 SG 552-1 Commando Barrel Replacement: passo 5, imagem 2 %32
      • Carefully tug on the tip of the gun and pull the barrel and its cover out.
      Pergunte ao FixBot
      Comentar
    6. SG 552-1 Commando Barrel Replacement: passo 6, imagem 1 %32 SG 552-1 Commando Barrel Replacement: passo 6, imagem 2 %32 SG 552-1 Commando Barrel Replacement: passo 6, imagem 3 %32
      • Pull the barrel out from the cover.
      • Remove the pieces at the end of the barrel.
      Pergunte ao FixBot
      Comentar
    7. SG 552-1 Commando Barrel Replacement: passo 7, imagem 1 %32 SG 552-1 Commando Barrel Replacement: passo 7, imagem 2 %32
      • Remove the remaining pieces of on the ends of the barrel.
      Pergunte ao FixBot
      Comentar
Conclusão
Laura Schulz
Membro desde: 10/05/12
1 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 18-41, Regan Fall 2012 Membro de Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 36
Ao todo: 2,054
