Ir para o conteúdo principal
SEGA Genesis Flashback Controller Buttons Replacement
O que você precisa
  1. SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: passo 1, imagem 1 %32 SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: passo 1, imagem 2 %32 SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: passo 1, imagem 3 %32
    • Hold the controller with the bottom plate facing up, and gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
    • Remove the screws on the back of the controller with the Phillips #000 screwdriver.
    • Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
    Pergunte ao FixBot
    Comentar
  2. SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: passo 2, imagem 1 %32 SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: passo 2, imagem 2 %32
    • CAUTION: Pull gently on the rubber membranes to avoid tearing .
    • Use two fingers to remove each rubber membrane that rests on top of the buttons.
    Pergunte ao FixBot
    Comentar
  3. SEGA Genesis Flashback Controller Buttons Replacement: passo 3, imagem 1 %32
    • Pop the button out from the front side of the controller.
    • Pull the button out from the backside using the other hand.
    • All removable buttons can only be placed in their respective holes due to unique groove patterns on the buttons. Keep in mind where each button belongs to make re-assembly easier.
    • All buttons can be removed except for the D-Pad.
    Pergunte ao FixBot
    Comentar
  4. SEGA Genesis Flashback Controller Buttons Replacement: passo 4, imagem 1 %32
    • Repeat Step 3 for the remaining buttons.
    • The button should pop out seamlessly and placed to the side.
    • Repeat the prior steps in order to remove all the buttons. Set them aside in an order you will remember to where they belong.
    Pergunte ao FixBot
    Comentar
Conclusão
After completing step 4 you will need to re-assemble your controller. Do this by starting from step 2 and work backwards. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
Viet Nguyen
Membro desde: 04/17/18
220 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S24-G12, Maness Spring 2018 Membro de Cal Poly, Team S24-G12, Maness Spring 2018
CPSU-MANESS-S18S24G12
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 51
Ao todo: 2,218
