Ir para o conteúdo principal
SEGA Genesis Flashback Back Cover Replacement
O que você precisa
  1. SEGA Genesis Flashback Back Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • Scratch off the right-hand side of the sticker at the center of the bottom case using the spudger until the screw is visible.
    • Remove this screw with the Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. SEGA Genesis Flashback Back Cover Replacement: passo 2, imagem 1 %32
    • Remove the two visible screws on the bottom with the Phillips #000 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. SEGA Genesis Flashback Back Cover Replacement: passo 3, imagem 1 %32 SEGA Genesis Flashback Back Cover Replacement: passo 3, imagem 2 %32
    • Use your fingers to peel off the four corner rubber feet on the bottom.
    • Use the Phillips #000 screwdriver to remove the four screws beneath the rubber feet.
    Pergunte ao FixBot
    Comentar
  4. SEGA Genesis Flashback Back Cover Replacement: passo 4, imagem 1 %32
    • Flip the case to its upright position.
    • Place one hand on the bottom plate of the case and one on the top plate. Gently pull apart the two plates by tilting the top plate about the front of the device. Treat the front of the device as a hinge.
    • Remove the back cover from the device.
    • Be sure not to rip the wire connection of the LED bulb that is still connected to the bottom plate.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Viet Nguyen
Membro desde: 04/17/18
220 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S24-G12, Maness Spring 2018 Membro de Cal Poly, Team S24-G12, Maness Spring 2018
CPSU-MANESS-S18S24G12
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 40
Ao todo: 1,062
