Ir para o conteúdo principal
Ryobi P501G Shell Replacement
O que você precisa
    1. Ryobi P501G Shell Replacement, Blade: passo 1, imagem 1 %32
      • Locate the area where the blade is connected to the motor, where the circular covering is on the Ryobi P501G.
      Pergunte ao FixBot
      Comentar
    2. Ryobi P501G Shell Replacement: passo 2, imagem 1 %32 Ryobi P501G Shell Replacement: passo 2, imagem 2 %32
      • Unscrew clockwise and remove the bearing in the middle, connecting the blade to the motor. This will also allow removal of the blade guard.
      Pergunte ao FixBot
      Comentar
    3. Ryobi P501G Shell Replacement: passo 3, imagem 1 %32 Ryobi P501G Shell Replacement: passo 3, imagem 2 %32 Ryobi P501G Shell Replacement: passo 3, imagem 3 %32
      • Remove the four black screws holding the black bearing and remove the bearing itself.
      Pergunte ao FixBot
      Comentar
    4. Ryobi P501G Shell Replacement: passo 4, imagem 1 %32
      • Once the black bearing is off, remove the transparent cover of the blade.
      • Once the cover is off, remove the blade.
      • Place the new blade with the flat notches lined up with the flat notches on the motor axle.
      Pergunte ao FixBot
      Comentar
    1. Ryobi P501G Shell Replacement, Shell: passo 5, imagem 1 %32 Ryobi P501G Shell Replacement, Shell: passo 5, imagem 2 %32 Ryobi P501G Shell Replacement, Shell: passo 5, imagem 3 %32
      • Remove the three screws on the inside base of the metal casing of the blade.
      • Pull the metal blade casing off of the Ryobi P501G body.
      Pergunte ao FixBot
      Comentar
    2. Ryobi P501G Shell Replacement: passo 6, imagem 1 %32 Ryobi P501G Shell Replacement: passo 6, imagem 2 %32 Ryobi P501G Shell Replacement: passo 6, imagem 3 %32
      • Remove all of the screws located on the right side of the saw.
      • Separate the right side of the saw from the left side by pulling away once all of the screws are removed.
      • Pull back the shell to access the housed parts underneath.
      Pergunte ao FixBot
      Comentar
Conclusão
Eeshan Mishra
Membro desde: 01/24/19
424 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S1-G2, Maness Spring 2019 Membro de Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 Membros
Autoria de 49 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 24
Ao todo: 713
