Ir para o conteúdo principal
Ryobi P235 Direction of Rotation Selector Replacement
O que você precisa
    1. Ryobi P235 Direction of Rotation Selector Replacement, Battery: passo 1, imagem 1 %32 Ryobi P235 Direction of Rotation Selector Replacement, Battery: passo 1, imagem 2 %32
      • Push in both push tabs on the battery at the same time.
      • They are located below the green housing and are in the middle on both sides of the battery.
      Pergunte ao FixBot
      Comentar
    2. Ryobi P235 Direction of Rotation Selector Replacement: passo 2, imagem 1 %32 Ryobi P235 Direction of Rotation Selector Replacement: passo 2, imagem 2 %32
      • Pull the battery away from the drill housing while holding in both tabs.
      Pergunte ao FixBot
      Comentar
    1. Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: passo 3, imagem 1 %32 Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: passo 3, imagem 2 %32
      • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
      Pergunte ao FixBot
      Comentar
    2. Ryobi P235 Direction of Rotation Selector Replacement: passo 4, imagem 1 %32 Ryobi P235 Direction of Rotation Selector Replacement: passo 4, imagem 2 %32
      • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
      Pergunte ao FixBot
      Comentar
    3. Ryobi P235 Direction of Rotation Selector Replacement: passo 5, imagem 1 %32 Ryobi P235 Direction of Rotation Selector Replacement: passo 5, imagem 2 %32
      • Open the housing with the data label facing up.
      Pergunte ao FixBot
      Comentar
    4. Ryobi P235 Direction of Rotation Selector Replacement: passo 6, imagem 1 %32 Ryobi P235 Direction of Rotation Selector Replacement: passo 6, imagem 2 %32
      • Lift the internal components out of the housing.
      Pergunte ao FixBot
      Comentar
    5. Ryobi P235 Direction of Rotation Selector Replacement: passo 7, imagem 1 %32 Ryobi P235 Direction of Rotation Selector Replacement: passo 7, imagem 2 %32
      • Remove the gray plastic forward/reverse selector.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 38
Ao todo: 1,336
