Ir para o conteúdo principal
Ryobi D620H Power Cord Replacement
O que você precisa
    1. Ryobi D620H Power Cord Replacement, Right Side Case Removal: passo 1, imagem 1 %32
      • Turn the drill so that the screws face upwards.
      • Use the Torx T20 screwdriver to remove all nine screws.
      Pergunte ao FixBot
      Comentar
    2. Ryobi D620H Power Cord Replacement: passo 2, imagem 1 %32 Ryobi D620H Power Cord Replacement: passo 2, imagem 2 %32
      • Insert the end of an opening tool between the right and left sides of the drill to pry the right side of the case.
      • Remove the right side case to expose the inside of the drill.
      Pergunte ao FixBot
      Comentar
    1. Ryobi D620H Power Cord Replacement, Power Cord: passo 3, imagem 1 %32
      • The bend relief cover at the bottom of the handle.
      • Follow the wires coming out of the bend relief cover to the white power cord clamp with the two 14 mm black PH1 screws.
      Pergunte ao FixBot
      Comentar
    2. Ryobi D620H Power Cord Replacement: passo 4, imagem 1 %32 Ryobi D620H Power Cord Replacement: passo 4, imagem 2 %32
      • Unscrew the two 14 mm PH1 screws holding the power cord wire in place.
      • Lift the switch box from its place gently.
      Pergunte ao FixBot
      Comentar
    3. Ryobi D620H Power Cord Replacement: passo 5, imagem 1 %32 Ryobi D620H Power Cord Replacement: passo 5, imagem 2 %32 Ryobi D620H Power Cord Replacement: passo 5, imagem 3 %32
      • Remove the two little screws holding the brass terminal lugs in place. Although it is not required, you can remove the screws completely if you find that doing so is more convenient.
      • Gently pull the white positive and black negative wires that are connected to the switch box.
      • Slide the bend relief guard off the cord towards the loose connections.
      Pergunte ao FixBot
      Comentar
Conclusão
Slide the bend relief cover on the new power cord and reattach all of the electrical connections in reverse order.
Congratulations you've successfully replaced the power cord on your hammer drill!
Jacob da Ponte
Membro desde: 10/30/23
469 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-2, Petersen Fall 2023 Membro de UMass Dartmouth, Team 1-2, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G2
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 366
