Ir para o conteúdo principal
Rug Doctor Hinge Plate Rivet Replacement
O que você precisa
  1. Rug Doctor Hinge Plate Rivet Replacement, Handle: passo 1, imagem 1 %32
    • Before you begin disassembly, make sure that the Rug Doctor is not plugged in and that all reservoirs are empty of liquids.
    • Unclip the clear hose from the back of the Rug Doctor.
  2. Rug Doctor Hinge Plate Rivet Replacement: passo 2, imagem 1 %32 Rug Doctor Hinge Plate Rivet Replacement: passo 2, imagem 2 %32
    • Use a 7/16" (11 mm OK) wrench to hold the handle axle while you use a 7/16" socket to remove the cap nut securing the axle end.
  3. Rug Doctor Hinge Plate Rivet Replacement: passo 3, imagem 1 %32 Rug Doctor Hinge Plate Rivet Replacement: passo 3, imagem 2 %32
    • Support the handle with one hand. It will be loose after this step.
    • Use fingers or pliers to pull out the handle axle.
    • If the axle feels hard to pull out, squeeze the handle release lever to release pressure on the axle.
  4. Rug Doctor Hinge Plate Rivet Replacement: passo 4, imagem 1 %32
    • Detach the handle from the Rug Doctor and set it down.
    • If you need more cable slack, you can set the Rug Doctor on its side.
  5. Rug Doctor Hinge Plate Rivet Replacement, Hinge Plate Rivet: passo 5, imagem 1 %32 Rug Doctor Hinge Plate Rivet Replacement, Hinge Plate Rivet: passo 5, imagem 2 %32 Rug Doctor Hinge Plate Rivet Replacement, Hinge Plate Rivet: passo 5, imagem 3 %32
    • This step shows how to drill a rivet out.
    • Center a sharp 3/16" drill bit on the rivet head's indentation.
    • Drill at slow to medium speed while applying steady pressure.
    • Drill about 1/3" deep—enough to drill past the rivet head and into the shaft.
    • Use a center punch and mallet to tap the shaft away from the head. Remove the rivet head.
    • You may not be able to retrieve the rivet shaft. This is normal.
  6. Rug Doctor Hinge Plate Rivet Replacement: passo 6, imagem 1 %32 Rug Doctor Hinge Plate Rivet Replacement: passo 6, imagem 2 %32 Rug Doctor Hinge Plate Rivet Replacement: passo 6, imagem 3 %32
    • This step shows how to install a pop rivet using a rivet gun.
    • Fully insert the stem of a 3/16" (5 mm) pop rivet into the rivet gun. The rivet gun should have a 3/16" adapter.
    • Insert the other end of the rivet into the hole.
    • Press the rivet gun firmly against the hinge plate.
    • Squeeze the rivet gun's handle completely closed. Repeat until the rivet stem breaks off.
Conclusão
To reassemble your device, follow these instructions in reverse order while noting the re-assembly tips.
5 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
258.910 Reputação
Autoria de 531 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.077 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 43
Duração total: 2,170
