Ir para o conteúdo principal
Rowenta Focus Power Assembly Replacement
O que você precisa
  1. Rowenta Focus Power Assembly Replacement, Power Assembly: passo 1, imagem 1 %32 Rowenta Focus Power Assembly Replacement, Power Assembly: passo 1, imagem 2 %32
    • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
    • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
    Pergunte ao FixBot
    Comentar
  2. Rowenta Focus Power Assembly Replacement: passo 2, imagem 1 %32 Rowenta Focus Power Assembly Replacement: passo 2, imagem 2 %32 Rowenta Focus Power Assembly Replacement: passo 2, imagem 3 %32
    • Pry the back cover of the iron off using a metal spudger.
    • Remove the back cover, exposing the wiring in the iron.
    Pergunte ao FixBot
    Comentar
  3. Rowenta Focus Power Assembly Replacement: passo 3, imagem 1 %32 Rowenta Focus Power Assembly Replacement: passo 3, imagem 2 %32
    • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
    • Leave the other cords attached to the main cord.
    Pergunte ao FixBot
    Comentar
  4. Rowenta Focus Power Assembly Replacement: passo 4, imagem 1 %32 Rowenta Focus Power Assembly Replacement: passo 4, imagem 2 %32
    • Pull out the motherboard inside handle of iron.
    • Keep it attached to main power cord and other components.
    Pergunte ao FixBot
    Comentar
  5. Rowenta Focus Power Assembly Replacement: passo 5, imagem 1 %32 Rowenta Focus Power Assembly Replacement: passo 5, imagem 2 %32 Rowenta Focus Power Assembly Replacement: passo 5, imagem 3 %32
    • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device with new power supply, follow these instructions in reverse order.
4 outras pessoas executaram este guia.
2Comentários do guia
Thanks... Where we can get parts
Baiju Vasavan - Responder Compartilhar
Tengo un Rowenta de la que se recoge el cable pero no veo los tornillos por donde destaparla
Jose Rojas - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 157
Ao todo: 8,442
