Ir para o conteúdo principal
Rowenta Focus Material Setting Knob Replacement
O que você precisa
  1. Rowenta Focus Material Setting Knob Replacement, Power Assembly: passo 1, imagem 1 %32 Rowenta Focus Material Setting Knob Replacement, Power Assembly: passo 1, imagem 2 %32
    • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
    • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
    Pergunte ao FixBot
    Comentar
  2. Rowenta Focus Material Setting Knob Replacement: passo 2, imagem 1 %32 Rowenta Focus Material Setting Knob Replacement: passo 2, imagem 2 %32 Rowenta Focus Material Setting Knob Replacement: passo 2, imagem 3 %32
    • Pry the back cover of the iron off using a metal spudger.
    • Remove the back cover, exposing the wiring in the iron.
    Pergunte ao FixBot
    Comentar
  3. Rowenta Focus Material Setting Knob Replacement: passo 3, imagem 1 %32 Rowenta Focus Material Setting Knob Replacement: passo 3, imagem 2 %32
    • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
    • Leave the other cords attached to the main cord.
    Pergunte ao FixBot
    Comentar
  4. Rowenta Focus Material Setting Knob Replacement: passo 4, imagem 1 %32 Rowenta Focus Material Setting Knob Replacement: passo 4, imagem 2 %32
    • Pull out the motherboard inside handle of iron.
    • Keep it attached to main power cord and other components.
    Pergunte ao FixBot
    Comentar
  5. Rowenta Focus Material Setting Knob Replacement: passo 5, imagem 1 %32 Rowenta Focus Material Setting Knob Replacement: passo 5, imagem 2 %32 Rowenta Focus Material Setting Knob Replacement: passo 5, imagem 3 %32
    • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
    Pergunte ao FixBot
    Comentar
  6. Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: passo 6, imagem 1 %32 Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: passo 6, imagem 2 %32 Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: passo 6, imagem 3 %32
    • Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
    • Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
    • Lift out the piece.
    Pergunte ao FixBot
    Comentar
  7. Rowenta Focus Material Setting Knob Replacement: passo 7, imagem 1 %32 Rowenta Focus Material Setting Knob Replacement: passo 7, imagem 2 %32 Rowenta Focus Material Setting Knob Replacement: passo 7, imagem 3 %32
    • Replace with an identical part by inserting it into the space.
    Pergunte ao FixBot
    Comentar
  8. Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: passo 8, imagem 1 %32 Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: passo 8, imagem 2 %32
    • Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
    Pergunte ao FixBot
    Comentar
  9. Rowenta Focus Material Setting Knob Replacement: passo 9, imagem 1 %32 Rowenta Focus Material Setting Knob Replacement: passo 9, imagem 2 %32
    • Unhook the clips on the top of the metal piece.
    • Using the metal spudger, remove the metal piece on the tip of the iron.
    Pergunte ao FixBot
    Comentar
  10. Rowenta Focus Material Setting Knob Replacement: passo 10, imagem 1 %32 Rowenta Focus Material Setting Knob Replacement: passo 10, imagem 2 %32
    • Using the T20 screwdriver, remove the 20 mm screw that was under the metal piece on the tip of the iron.
    Pergunte ao FixBot
    Comentar
  11. Rowenta Focus Material Setting Knob Replacement: passo 11, imagem 1 %32 Rowenta Focus Material Setting Knob Replacement: passo 11, imagem 2 %32 Rowenta Focus Material Setting Knob Replacement: passo 11, imagem 3 %32
    • Using the T20 screwdriver, remove the two 20 mm screws on either side of the back of the iron.
    Pergunte ao FixBot
    Comentar
  12. Rowenta Focus Material Setting Knob Replacement: passo 12, imagem 1 %32 Rowenta Focus Material Setting Knob Replacement: passo 12, imagem 2 %32 Rowenta Focus Material Setting Knob Replacement: passo 12, imagem 3 %32
    • Lift the iron up using the handle to completely detach the soleplate.
    Pergunte ao FixBot
    Comentar
  13. Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: passo 13, imagem 1 %32 Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: passo 13, imagem 2 %32 Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: passo 13, imagem 3 %32
    • Using the T20 screwdriver, remove both of the 20mm screws on the underside of the iron.
    Pergunte ao FixBot
    Comentar
  14. Rowenta Focus Material Setting Knob Replacement: passo 14, imagem 1 %32 Rowenta Focus Material Setting Knob Replacement: passo 14, imagem 2 %32
    • Turn the iron over and pull the knob off.
    • Be careful not to tip the iron after removing the knob; there are small springs in the white piece underneath the knob.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
1Comentário do guia
Nice pics, came apart easily with this guide. Just need a note on the small ball bearing which I assume goes somewhere on the steam valve?
Step - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 80
Ao todo: 2,311
