Ir para o conteúdo principal
Roku XD 2050X Remote IR LED Replacement
O que você precisa
  1. Roku XD 2050X Remote IR LED Replacement, Remote Control Casing: passo 1, imagem 1 %32 Roku XD 2050X Remote IR LED Replacement, Remote Control Casing: passo 1, imagem 2 %32
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Remove the battery cover.
    • Remove the two AA batteries.
    Pergunte ao FixBot
  2. Roku XD 2050X Remote IR LED Replacement: passo 2, imagem 1 %32 Roku XD 2050X Remote IR LED Replacement: passo 2, imagem 2 %32
    • Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
    • Gently twist the spudger to separate the top and bottom halves of the remote.
    Pergunte ao FixBot
  3. Roku XD 2050X Remote IR LED Replacement: passo 3, imagem 1 %32
    • Gently use the spudger to pry the circuit board loose.
    Pergunte ao FixBot
  4. Roku XD 2050X Remote IR LED Replacement: passo 4, imagem 1 %32
    • Using either end of the spudger, gently lift and remove the clear keypad backing.
    Pergunte ao FixBot
  5. Roku XD 2050X Remote IR LED Replacement: passo 5, imagem 1 %32
    • Using either end of the spudger, lift and remove the rubber keypad.
    Pergunte ao FixBot
  6. Roku XD 2050X Remote IR LED Replacement, Remote IR LED: passo 6, imagem 1 %32
    • Desolder the two contacts for the IR LED.
    • Remove the IR LED from the circuit board.
    • For help with soldering view the ifixit soldering guide.
    Pergunte ao FixBot
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 29
Ao todo: 1,136
