Ir para o conteúdo principal
Roku XD 2050X Remote Battery Terminal Replacement
O que você precisa
  1. Roku XD 2050X Remote Battery Terminal Replacement, Remote Control Casing: passo 1, imagem 1 %32 Roku XD 2050X Remote Battery Terminal Replacement, Remote Control Casing: passo 1, imagem 2 %32
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Remove the battery cover.
    • Remove the two AA batteries.
  2. Roku XD 2050X Remote Battery Terminal Replacement: passo 2, imagem 1 %32 Roku XD 2050X Remote Battery Terminal Replacement: passo 2, imagem 2 %32
    • Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
    • Gently twist the spudger to separate the top and bottom halves of the remote.
  3. Roku XD 2050X Remote Battery Terminal Replacement: passo 3, imagem 1 %32
    • Gently use the spudger to pry the circuit board loose.
  4. Roku XD 2050X Remote Battery Terminal Replacement: passo 4, imagem 1 %32
    • Using either end of the spudger, gently lift and remove the clear keypad backing.
  5. Roku XD 2050X Remote Battery Terminal Replacement: passo 5, imagem 1 %32
    • Using either end of the spudger, lift and remove the rubber keypad.
  6. Roku XD 2050X Remote Battery Terminal Replacement, Remote Battery Terminal: passo 6, imagem 1 %32
    • Desolder the contacts for the battery terminals.
    • Remove the battery terminals from the circuit board.
    • For hep with soldering view the ifixit soldering guide.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,210
