Introdução
Use this guide to replace a damaged or malfunctioning audio port on the Roku XD 2050X. To complete this guide, you will need to disassemble your device and use a soldering iron to replace the port.
O que você precisa
Turn the device upside down.
Remove the two rubber pads using a plastic spudger.
Desolder the leads for the audio port that you wish to replace.
Left audio port leads are circled in red.
Right audio port leads are circled in orange.
Remove the audio port from board.
For help with soldering view the iFixit soldering guide.
