Ir para o conteúdo principal
Roku 3 Remote Control Buttons Replacement
O que você precisa
  1. Roku 3 Remote Control Buttons Replacement, Remote Control Battery: passo 1, imagem 1 %32
    • Flip the remote over so that the buttons are facing down and the end with the wrist strap is nearest your right hand.
    Pergunte ao FixBot
    Comentar
  2. Roku 3 Remote Control Buttons Replacement: passo 2, imagem 1 %32 Roku 3 Remote Control Buttons Replacement: passo 2, imagem 2 %32
    • Press and hold the black tab above the battery compartment.
    • While holding down the tab with your left hand, slide down the battery compartment cover with your right hand to remove it.
    Pergunte ao FixBot
    Comentar
  3. Roku 3 Remote Control Buttons Replacement: passo 3, imagem 1 %32
    • Remove the batteries by placing a finger on one end of the battery and pushing downward while pulling the battery out.
    Pergunte ao FixBot
    Comentar
  4. Roku 3 Remote Control Buttons Replacement, Remote Control Buttons: passo 4, imagem 1 %32 Roku 3 Remote Control Buttons Replacement, Remote Control Buttons: passo 4, imagem 2 %32
    • Unscrew one 7 mm Phillips #0 screw from the center of the battery compartment.
    Pergunte ao FixBot
    Comentar
  5. Roku 3 Remote Control Buttons Replacement: passo 5, imagem 1 %32 Roku 3 Remote Control Buttons Replacement: passo 5, imagem 2 %32
    • Gently pry open the remote using the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  6. Roku 3 Remote Control Buttons Replacement: passo 6, imagem 1 %32 Roku 3 Remote Control Buttons Replacement: passo 6, imagem 2 %32
    • Separate the top and bottom of the remote casing.
    • Gently place each half of the remote onto a table so that the exteriors are face down.
    • The remote buttons, sensors, and motherboard are not attached to anything inside the remote. Take apart the remote with caution to ensure these components do not accidentally fall out.
    Pergunte ao FixBot
    Comentar
  7. Roku 3 Remote Control Buttons Replacement: passo 7, imagem 1 %32
    • Carefully flip over the front casing side of the remote so that the buttons drop onto the table.
    • If the buttons do not drop immediately, use your fingers to peal them off the front casing of the remote.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 15-2, Livingston Fall 2016 Membro de Cal Poly, Team 15-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G2
3 Membros
Autoria de 6 guias
4Comentários do guia
Do you have a source for getting replacement buttons? I have volume buttons that don't work and was hoping to fix them/ replace them. Thank you!
Patrick Canady - Responder Compartilhar
Hi Patrick,
I literally just finished successfully fixing my volume-up button.
The replacement part number for the right microswitches is EVQ-P7J01P, available at Digi-Key:
https://www.digikey.com/product-detail/e...
Really inexpensive (around 30 cents each). Pro-tip - to help remove the old switch easily, cut it in half with sharp side-cutters.
Good luck!
Jeff T.
J Thomson - Responder Compartilhar
Where can I find a component layout?
Rey De Castro - Responder Compartilhar
Setuproku provides support for all roku related issue. This article help us to understand the Roku remote control.
setuproku code - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 41
Ao todo: 6,485
