Ir para o conteúdo principal
Roku 3 Remote Control Battery Replacement
O que você precisa
  1. Roku 3 Remote Control Battery Replacement, Remote Control Battery: passo 1, imagem 1 %32
    • Flip the remote over so that the buttons are facing down and the end with the wrist strap is nearest your right hand.
    Pergunte ao FixBot
    Comentar
  2. Roku 3 Remote Control Battery Replacement: passo 2, imagem 1 %32 Roku 3 Remote Control Battery Replacement: passo 2, imagem 2 %32
    • Press and hold the black tab above the battery compartment.
    • While holding down the tab with your left hand, slide down the battery compartment cover with your right hand to remove it.
    Pergunte ao FixBot
    Comentar
  3. Roku 3 Remote Control Battery Replacement: passo 3, imagem 1 %32
    • Remove the batteries by placing a finger on one end of the battery and pushing downward while pulling the battery out.
    Pergunte ao FixBot
    Comentar
Conclusão
Isobelle Espiritu
Membro desde: 10/06/16
591 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 15-2, Livingston Fall 2016 Membro de Cal Poly, Team 15-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G2
3 Membros
Autoria de 6 guias
2Comentários do guia
no tab on the roku 3 still can't get it open
eve.m.waterman - Responder Compartilhar
no tab, cannot open battery compartment
Fred Badders - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 45
Ao todo: 27,820
