Ir para o conteúdo principal
Roku 3 A/C Power Port Replacement
O que você precisa
  1. Roku 3 A/C Power Port Replacement, Motherboard: passo 1, imagem 1 %32
    • Place the Roku 3 on the table face down and orient it so you can correctly read the writing.
  2. Roku 3 A/C Power Port Replacement: passo 2, imagem 1 %32 Roku 3 A/C Power Port Replacement: passo 2, imagem 2 %32 Roku 3 A/C Power Port Replacement: passo 2, imagem 3 %32
    • Pull back the rubber protection in the top right corner to locate the screw.
    • Repeat with the bottom right corner and bottom left corner.
  3. Roku 3 A/C Power Port Replacement: passo 3, imagem 1 %32
    • Remove the 9 mm screws from the three corners with a Hex 1.3 Screwdriver.
  4. Roku 3 A/C Power Port Replacement: passo 4, imagem 1 %32 Roku 3 A/C Power Port Replacement: passo 4, imagem 2 %32
    • Open the device by gently lifting the bottom half away from the top half of the device.
  5. Roku 3 A/C Power Port Replacement: passo 5, imagem 1 %32
    • Use your fingers to carefully lift the motherboard from the top half of the device.
  6. Roku 3 A/C Power Port Replacement: passo 6, imagem 1 %32 Roku 3 A/C Power Port Replacement: passo 6, imagem 2 %32
    • Pull away the IO shield from the motherboard using your hands.
  7. Roku 3 A/C Power Port Replacement, A/C Power Port: passo 7, imagem 1 %32 Roku 3 A/C Power Port Replacement, A/C Power Port: passo 7, imagem 2 %32
    • Turn over the motherboard so the back is face up and almost all large silver components are resting facedown on the table.
    • Orient it such that the backside of the HDMI port is in your upper right corner.
  8. Roku 3 A/C Power Port Replacement: passo 8, imagem 1 %32
    • Desolder the connections of the A/C Power Port on the motherboard.
    • Remove the port.
    • For more information on soldering, check out iFixit's Soldering Guide.
Conclusão
Uma outra pessoa concluiu este guia.
Andy Hak
Membro desde: 10/07/16
250 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 15-2, Livingston Fall 2016 Membro de Cal Poly, Team 15-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G2
Membros da 3
Autoria de 6 guias
Um comentário
What’s the size and name of the actual jack? Where do I get a replacement one?
Bo Northwest Designs of SE - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 2,480
