Ir para o conteúdo principal
Roku 2 Remote Control Buttons Replacement
O que você precisa
  1. Roku 2 Remote Control Buttons Replacement, Remote Battery: passo 1, imagem 1 %32
    • Turn over remote and press down on tab to remove.
    Pergunte ao FixBot
    Comentar
  2. Roku 2 Remote Control Buttons Replacement: passo 2, imagem 1 %32
    • Remove batteries
    Pergunte ao FixBot
    Comentar
  3. Roku 2 Remote Control Buttons Replacement: passo 3, imagem 1 %32
    • Place the new batteries into the remote. Make sure the positive terminal is facing the positive terminal of the slot. Similarly the negative terminal should be touching the negative terminal. If done right the batteries should be facing opposite directions of each other.
    • Insert Roku tab back on to its slot.
    Pergunte ao FixBot
    Comentar
  4. Roku 2 Remote Control Buttons Replacement, Remote Control Buttons: passo 4, imagem 1 %32
    • After removing the batteries, use a #000 Phillips to remove the screw.
    Pergunte ao FixBot
    Comentar
  5. Roku 2 Remote Control Buttons Replacement, Pry the remote open: passo 5, imagem 1 %32
    • Use a plastic opening tool to pry open the remote.
    Pergunte ao FixBot
    Comentar
  6. Roku 2 Remote Control Buttons Replacement: passo 6, imagem 1 %32
    • Continue along the top of the remote to lift it off the remote.
    • Lift the top of the remote off very carefully so that board doesn't fall.
    Pergunte ao FixBot
    Comentar
  7. Roku 2 Remote Control Buttons Replacement, Replace the buttons: passo 7, imagem 1 %32
    • Identify the buttons to be replaced and take them out.
    Pergunte ao FixBot
    Comentar
Conclusão
10 outras pessoas executaram este guia.
Alex Saltos
Membro desde: 08/27/15
526 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-5, Sullivan Fall 2015 Membro de USF Tampa, Team 1-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G5
3 Membros
Autoria de 7 guias
9Comentários do guia
Well, hmmm; why is it there is actually no screws in mine nor the ones for others. None in mine and 4 in the ones for volume control over tlc tv's etc??
Junebug - Responder Compartilhar
I use my mobile to control and I download it at: https://apps.apple.com/us/app/roku-remot...
It's better for me
donor - Responder Compartilhar
And where exactly do you buy the new buttons ??
bonzo dog - Responder Compartilhar
And just where exactly do you buy the new buttons??
So I tried every trick to get my remote to work (all the Youtube tricks). Found this, took the remote apart and got it to work with the cover off. New remote coming in two days but I just wanted to say thanks cause now I can watch TV while I wait for my new remote to arrive!!!!!!!!!!! I would not advise using the remote with the cover off, just sayin, but I am lol….
Joe MacRitchie - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 28
Últimos 30 dias: 129
Ao todo: 56,654
