Ir para o conteúdo principal
Roku 2 A/C Power Port Replacement
O que você precisa
  1. Roku 2  A/C Power Port Replacement, Roku 2 Motherboard: passo 1, imagem 1 %32
    • Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
    • It may take multiple heats, left for a minute at a time, to properly loosen the glue.
  2. Roku 2  A/C Power Port Replacement: passo 2, imagem 1 %32
    • Gently use the plastic opening tool to pry the rubber pads off.
  3. Roku 2  A/C Power Port Replacement: passo 3, imagem 1 %32
    • Remove the four Phillips #000 screws from the bottom of the case.
  4. Roku 2  A/C Power Port Replacement: passo 4, imagem 1 %32
    • Gently remove the under side of the device.
  5. Roku 2  A/C Power Port Replacement: passo 5, imagem 1 %32
    • Remove the middle component that is held in place by the top and bottom of the device.
  6. Roku 2  A/C Power Port Replacement: passo 6, imagem 1 %32
    • Remove the cover over the A/V ports on the front of the device.
  7. Roku 2  A/C Power Port Replacement: passo 7, imagem 1 %32
    • Remove the board from the plastic enclosure.
  8. Roku 2  A/C Power Port Replacement, A/C Power Port: passo 8, imagem 1 %32
    • Heat the 3 solder leads on the bottom side of the motherboard opposite of the A/C Port until the point you can pull the port away from the board.
    • To learn more about soldering check out the Soldering Technique Guide.
  9. Roku 2  A/C Power Port Replacement: passo 9, imagem 1 %32
    • Insert the new A/C power port where the old one was. Gently apply solder to the 3 pins on the bottom side of the mother board to connect it.
Conclusão
david quintana
Membro desde: 08/27/15
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-5, Sullivan Fall 2015 Membro de USF Tampa, Team 1-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G5
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 1,314
