Ir para o conteúdo principal
Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement
O que você precisa
  1. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Sender: passo 1, imagem 1 %32
    • Remove the four rubber tabs from the bottom of the sender.
    • Pull hard to peel off the rubber tabs, as they are attached with adhesive.
    Pergunte ao FixBot
    Comentar
  2. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: passo 2, imagem 1 %32
    • Use a Phillips #1 screwdriver to unscrew the four 12 mm screws on the bottom of the device.
    Pergunte ao FixBot
    Comentar
  3. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: passo 3, imagem 1 %32 Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: passo 3, imagem 2 %32
    • Flip the device over and remove the top casing from the sender.
    Pergunte ao FixBot
    Comentar
  4. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement, Sender Wireless Audio Module Chip: passo 4, imagem 1 %32
    • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the wireless audio module chip.
    Pergunte ao FixBot
    Comentar
  5. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: passo 5, imagem 1 %32
    • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: passo 6, imagem 1 %32
    • Use a Phillips #1 screwdriver to unscrew the two 10 mm screws located on either side of the speakers.
    • Secure the front speaker input terminal to release the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: passo 7, imagem 1 %32 Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: passo 7, imagem 2 %32
    • Using both thumbs, push the front speaker input terminal back towards the inside part of the device.
    Pergunte ao FixBot
    Comentar
  8. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: passo 8, imagem 1 %32
    • Flip over the motherboard and wireless audio module chip.
    Pergunte ao FixBot
    Comentar
  9. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: passo 9, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Gently slide the black retaining flap back, securing the ribbon wire gently away from the white bar.
    • There should only be a small separation between the white bar and the black retaining flap.
    • Tweezers are recommended for this step.
    Pergunte ao FixBot
    Comentar
  10. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: passo 10, imagem 1 %32
    • Using your fingers, pull the ribbon wire out from the black retaining flap in order to completely disconnect the wireless audio module chip.
    Pergunte ao FixBot
    Comentar
Conclusão
To install the new wireless module chip, follow these instructions in reverse order.
Once the sender has been put back together, plug in the device and initiate the connection mode between the sender and receiver to ensure the new wireless module chip has been properly assembled.
Equipe
Baylor, Team 4-2, Williams Spring 2015 Membro de Baylor, Team 4-2, Williams Spring 2015
BU-WILLIAMS-S15S4G2
3 Membros
Autoria de 6 guias
3Comentários do guia
Does Rocketfish offer a replacement board?
Bob David - Responder Compartilhar
“No Parts Required” is a joke . Where are the replacement boards available from?
Petie Martin - Responder Compartilhar
I used the wrong ac adapter, which worked for a few weeks then the unit died and won't power on. Would anyone know what I should check out with the multi meter to see what's wrong and see if I can fix it? Thanks!
Adam Sawicki - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 34
Ao todo: 1,877
