Ir para o conteúdo principal
Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement
O que você precisa
  1. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Receiver: passo 1, imagem 1 %32
    • Remove the 4 rubber tabs on the bottom side of the receiver.
    Pergunte ao FixBot
    Comentar
  2. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: passo 2, imagem 1 %32
    • Unscrew the four 12 mm screws on the bottom side of the receiver.
    • Use a Phillips #1 screwdriver for this step.
    Pergunte ao FixBot
    Comentar
  3. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: passo 3, imagem 1 %32 Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: passo 3, imagem 2 %32
    • Remove top casing from the receiver.
    • The receiver top casing is difficult to remove. Internal clasps may have to be broken in order to remove the top casing (this will not effect the device's function)
    Pergunte ao FixBot
    Comentar
  4. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, Receiver Wireless Audio Module Chip: passo 4, imagem 1 %32
    • Unscrew the 10 mm screw holding the wireless audio module.
    Pergunte ao FixBot
    Comentar
  5. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: passo 5, imagem 1 %32 Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Slide the black retaining flap securing the ribbon cable away from the white bar.
    • There should be only a small space between the white bar and black retaining flap.
    • You may want to use tweezers for this step.
    Pergunte ao FixBot
    Comentar
  6. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: passo 6, imagem 1 %32
    • Using your fingers, slide the ribbon cable out from the under the black retaining flap to completely disconnect it from the device.
    Pergunte ao FixBot
    Comentar
Conclusão
To install the new wireless audio module chip, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Equipe
Baylor, Team 4-2, Williams Spring 2015 Membro de Baylor, Team 4-2, Williams Spring 2015
BU-WILLIAMS-S15S4G2
3 Membros
Autoria de 6 guias
1Comentário do guia
This is a very long time later, but where do you get the receiver chip??? Rocket fish doesn't support the product anymore
Michael Jay - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 29
Ao todo: 2,515
